Leak on the small pipe left of engine
There's a small pipe running along the left of the engine. It's metal first..then goes into a rubber housing, and then a normal pipe. What's that pipe for? I saw the rubber mounting has cracked and there's some leak around the joint (where the pipe meets the metal pipe part near the rubber gasket).
The pipe is behind the big obvious metal and rubber pipe in the picture.
Not near the car, but here's a google pic. Image
Edit:
From the looks of it, its the power steering hose.
Should replace the whole hose I'd imagine? Part number?
yotka
Re: Leak on the small pipe left of engine
Post by yotka »
Part number: MR197073
Description: High pressure power steering hose.
Product model: Mitsubishi FTO 2.0 V6 DE3A
Pretty sure I have 78 of them
yotka
Post by yotka »
You can get one made up locally, and will probably be cheaper.
I bought an original though, as replacement.
Mine is free
Sahin wrote:Mine is free
hah! damn it! where abouts you staying now? :P
Thanks Yotka!
Pm me if you want, it's at mums old place
The problem leak in question. How bad is it? :\
@Sahin, yeah will send you a ping.
