Power steering leaks / orings
Post by silverGPX » Tue Feb 14, 2017 11:25 am
Hi guys,
Just wondering if anyone has replaced their orings in the high pressure hose connection and the low pressure on the power steering pump.
Getting a mad leak on the pump.
Someone has suggested I just take the pump and line into a bearing/seal shop - is this the best option?
Cheers
Re: Power steering leaks / orings
Post by Daniel2019 » Wed Feb 15, 2017 4:31 pm
Yep I would. Or alternatively just pull out the seals and sh*t you need to replace and go get them matched up.
Post by silverGPX » Thu Feb 16, 2017 12:23 pm
Sorted.
