Proportioning Valve & Fan Belts
Devils
Post by Devils »
Hi, I just took my car for a wof, and they told me that my rear brakes have an uneven pressures which is due to the proportioning valve being filled with crap, I went down the road to my mechanic and he said given the age of the car (it's a 1993) it'll probably be easier to get another one rather than try to clear out the 1 on it, said it could cost between $50-$85 depending on how much the wreckers want to charge, I'm just wondering if anyone knows which newer model Mitsis share the same proportioning valve as a 1993 FTO GR
Second question, the wof place said my fanbelts were due for replacing, I was thinking about getting some from Supercheap, does anyone know which ones I need to get?
Cheers
Re: Proportioning Valve & Fan Belts
How do they test that?
Also they didn’t make FTOs in 93
mezje
Post by mezje »
Something sounds fishy, uneven brake pressures in the REAR, how would they even notice?
They go on rollers that measure the braking force
Devils
Post by Devils »
Okay a 1994 then, and what Spetz said.
Huh? Wof? Pom?
Nah, sheep shagger
Devils
Post by Devils »
That's probably why there are so many heaps of sh*t on your roads.
Nah, we just don't call it WOF.
