turbo water line
fto-007
turbo water line
Post by fto-007 »
hi
this might sound like a stupid question :roll: but where do you pick up the water lines off for a 6a12 turbo conversion?? just thought someone has done it before... :D cheers
Re: turbo water line
I take it your talking about the water lines for use as a spray unit on the intercooler?
If so add another window washer bottle and use that.
kermut
Post by kermut »
from your throttle body t piece
Yep from your throttle body. All you need to do is plumb it inline with your throttle body. Disconnect one hose an connect to your turbo inlet. Then take a from the outlet side of the turbo back to where you disconeected the first hose.
fto-007
Post by fto-007 »
sweet thanks just wasnt quite sure. :)
