6A12T anyone
d_dan
6A12T anyone
Post by d_dan »
Just wondering who else has actually turbo'd the fto engine and what power are you getting?
as it seems a lot of you guys seem to have done an engine conversion
AJ
Re: 6A12T anyone
Post by AJ »
173 atwKw's last time it was dyno'd before new turbo, FPR, uprated fuel pump etc.
viewtopic.php?f=22&t=21787&start=100
d_dan
Re: 6A12T anyone
Post by d_dan »
not too bad. am I right in thinking he has standard internals?
AJ
Re: 6A12T anyone
Post by AJ »
Yep, stock internals.
d_dan
Re: 6A12T anyone
Post by d_dan »
Thats not bad power at the wheels to be honest.
I should have dyno results in 3-4 weeks even though I have a fully forged build im not looking for big power as im looking to try get as much of it down as I can for racing
AJ
Re: 6A12T anyone
Post by AJ »
Yeah, it's a nice amount to have and thanks to the tip box I get very little wheel spin which makes for fast getaways.
d_dan
Re: 6A12T anyone
Post by d_dan »
do you think your loosing out on much compaired to a manual?
AJ
Re: 6A12T anyone
Post by AJ »
Not really. I'm happy with it the way it is. Where are you based?
d_dan
Re: 6A12T anyone
Post by d_dan »
Ireland.
Im using a lot of the same electronic kit as you.
But using a VF34 turbo from a type R suberau as its a very quick spooling turbo.
For now im using 350cc injector's
Fully forged internals. (iv the same extra injector but have decided to remove it.
im hoping to have the forged rebuild finished first week in september so ill let you know how I get on.
Have you played around with the mivec at all.
Have you MSN?
Re: 6A12T anyone
Off topic happy Bday d_dan :thumright: .
d_dan
Re: 6A12T anyone
Post by d_dan »
cheers mate. its still the 11th here :P
AJ
Re: 6A12T anyone
Post by AJ »
d_dan wrote:Ireland.
Have you MSN?
I'd be interested to hear what you did for the forging.
As for MIVEC, no I've not touched it.
I do have MSN but never go on it. Send me a PM and we'll take it form there if you like.
d_dan
Re: 6A12T anyone
Post by d_dan »
What compression are you running?
im using 8:5:1 compression gorged CP pistons, rings, gudgon pins.
Then using PAR forged I beam rods,
I was looking at your dyno printouts I recon the dip in power when you hit mivec is the loss of pressure due to the valve overlap with the mivec cam. have you played with the cam timing? Retarding the cams a little might help.
My plan is to change the camshafts mivec lobe to an agressive turbo profile and then change the Mivec from being RPM activated to have it Boost activated. So it should be very smooth down low as a cruiser but will be a different machine all together when the boot is down
Valandis91
Re: 6A12T anyone
Post by Valandis91 »
AJ wrote:Yeah, it's a nice amount to have and thanks to the tip box I get very little wheel spin which makes for fast getaways.
do you get wheel spin when you change gears?
or like surge forward as you change gear?
Mine does when im giving it to it just wondering if you did as well with the turbo or if its a NA thing?
d_dan
Re: 6A12T anyone
Post by d_dan »
I would have thought that that was the clutch biting in
AJ
Re: 6A12T anyone
Post by AJ »
If I'm running low boost, I just get the surge, if I'm running high boost then I get both :twisted:
