6a13 manifold
bigjiz
6a13 manifold
Post by bigjiz »
So with the 6a13 conversion, the only real drama is the rear manifold not fitting? So all I would have to do is make a costom one?
Re: 6a13 manifold
Just the rear turbo pipes as far as i know - best bet is to have a chat to bennoz if you can.
Re: 6a13 manifold
There's also the rad and something else... clutch or brake master cylinder... (dont know which one, I'm noob)
Re: 6a13 manifold
Yeah front turbo wont fit with factory fans & if you're using an FTO box, you've gotta modify the front wastegate to clear the clutch slave.
bigjiz
Re: 6a13 manifold
Post by bigjiz »
Will the 6a12 manifolds line up with the 13 heads? Cause I was thinking of single conversion instead of the doing the mods to go twin?
Re: 6a13 manifold
bigjiz wrote:Will the 6a12 manifolds line up with the 13 heads? Cause I was thinking of single conversion instead of the doing the mods to go twin?
I think they do... Cause there are a number of folks that have used the 6A13 manifolds with turbos on 6A12s in the UK..
