DIY: Repaint your wiper blades and plastic bits
mr-charisma
Post by mr-charisma »
The paint on my wiper blades was peeling and looking pretty crap, so I sprayed them black last weekend, also gave my front grill and windscreen seals a few coats as well to make them look all shiny-like again...
was a bit of a rush job to try and get it done before the cruise the next day so i sprayed it on a bit thick, but ...i'm fairly happy with the results..
If anyone is interested in respraying their car bits you will need:
Can of Spraypaint (whatever colour you like) - I used gloss black
Plastic primer - (If spraying plastic parts - Helps the paint stick to the plastic)
Prepsol (Grease remover) - Need to clean the plastic parts and get all the dust / grease etc off it before you paint/prime... as the paint is pretty fussy about it.
Dropsheets / Newspaper to cover areas you don't want to get covered in paint - You can pick up a plastic dropsheet from Big W in the paint section for like $2 - $3
Tools to get the wiper blades off - 12mm socket + S'Wrench
Getting the windscreen grill off is easy, just pop out the little plugs holding it in and lift it off - they may be brittle and break off if you're not careful
When spraying, do lots of light coats rather than thick coats and all of that basic spraypainting stuff that i completely ignored :P
khunjeng
Post by khunjeng »
nice one.
u do realise there is a styling section?
And a DIY section :wink:
EURO
Post by EURO »
I did this too, but if you want to make it even easier, dont even take wiper blades off.... I didnt need a primer either, just washed them and then painted and have had no problems two years later.
I left grill and blades where they are, paper all over the bonnet, windscreen etc, and just sprayed.
good little thing to do, amazing how much better the car looks.
Did the same thing to rear wiper as well.
msbchi
Post by msbchi »
Rather than spray-painting the plastic bits, I prefer a liberal dose of Armouralworks a treat. rejuvenates the plastic from that tired grey look back to a fresh black finish .... send all advertising royalties to peter C @ ... lol
If this is to warrant full DIY accreditation, i need to see pics!
EURO
Post by EURO »
msbchi wrote:Rather than spray-painting the plastic bits, I prefer a liberal dose of Armouralworks a treat. rejuvenates the plastic from that tired grey look back to a fresh black finish .... send all advertising royalties to peter C @ ... lol
lol but then you have to keep doing it every few weeks.... painting at least you do it once and then dont have to touch again for years..
FtoSam
Post by FtoSam »
I'll see about doing it this weekend and post up pics for ya ben.
eThix
Post by eThix »
Yeah i would like to see how this looks, mine need some doing :)
why not new unit all together?? Not expensive and offer a better wipe?
mr-charisma
I'll go take some pics now ... will get them hosted & posted soon. Don't have the 'before' pics, but i'm sure anyone wanting to try this knows what the 'before' looks like...
was a bit too rushed, but if you take your time with them & let each coat dry properly before doing the next one, they will look better..
Mel_star_1
Post by Mel_star_1 »
Great job, i done mine yesterday and came up a treat. :D
Thankx
[img]http://i122.photobucket.com/albums/o276/mel_star_1/melstar2ip8.jpg[/img]
Andym
Re: DIY: Repaint your wiper blades and plastic bits
Post by Andym »
didnt want to start a new thread, but i did this today and it turned out great. (the wipers and the plastic scuttle) but the rubber seal between the plastic and windscreen is goooooone, any tips on re-sealing this?
Andym wrote:didnt want to start a new thread, but i did this today and it turned out great. (the wipers and the plastic scuttle) but the rubber seal between the plastic and windscreen is goooooone, any tips on re-sealing this?
Mines stuffed too. If you find out, send tips my way! :lol:
