DIY: Changing Wiper Motor
FtoSam
Post by FtoSam »
You will need:
- Ratchet
- 10mm socket
- 12mm socket
- Pliers
- Flat head screwdriver
Time:
30 Minutes
Difficulty:
Easy peasy
Step 1:
Pull the wipers up off the windscreen so they point straight up.
Then with the 10mm socket take to the motor to undo the four bolts.
Then unplug the wires
Then pull it out from the firewall. Behind it is the bolt to the wipers:
Grab the metal plate with pliers and undo the bolt:
With the motor off, you'll most likely need to swap the plate over...
Dont forget to line up the drain plug
No simply whack it back in...
voila!
