WTB: Front ABS sensors
As per title.
Re: WTB: Front ABS sensors
Where exactly are they located? I'd have em here. Do believe your after a fair few other bits and pieces as well yeah?
They're located in the front hubs, can be a pain to remove though. Might be getting some off of Astron Boy, but wouldn't mind having some spares. Just be careful not to damage them as you remove them. haha.
You need to keep twisting them and spray wd40 in there until they loosen up.
Don't try hammering a screwdriver or chisel under the bracket or you could damage the barrel.
Maybe look up a guide or something.
And yeah, was after a few other bits.
Bump. Still looking for these.
I got whole set front and rear
Only downside is that plugs might be cut off but that shouldn't be an issue for someone like yourself
