Wtb speedo drive gear on diff
Private Sales Only
veegeeta
Post by veegeeta »
Hi guys I bought a wavetrac diff centre and need a speedo drive gear for it. The one on my fto box is one piece it's not pressed. What diff centre can I get one from. Thankyou
Re: Wtb speedo drive gear on diff
Ben and I both had one that also fit on a Cusco diff, can't be much more help than that I'm afraid!
Are you having any issues fitting the diff? (though I suppose if you don't have the speedo gear you haven't put it back together at all yet)
It's a Mitsubishi part number. If you Google the Wavetrac part number & find my thread on the Aus Magna forum, you'll find the part number. I may have also posted it in my build thread.
Found it, MD717879.
veegeeta
Post by veegeeta »
Thanks guys got one but won't see it till January real bummer. Cars having body work done engine and box are out .was pushing water out overflow bottle on high boost and getting hot. Found some sort of rubber gasket blocking water jets. So rebuild box with diff aswell.
