automatic torque converter & flex plate
Private Sales Only
wagonist
Post by wagonist »
Anyone got an old one sitting around? don't care if it's stuffed.
Mainly want the starter ring & the flex plate to get the hole pattern for the crankshaft.
daily driver:Toyota Caldina GTT manual
weekend racer: Hyundai Excel, Elantra 2L HVT engine & gearbox, Mitsi Eclipse LSD, FTO rear brakes, Mivec FTO front brakes
https://www.dropbox.com/sh/43b8k0fus8uu ... %20527.JPG
Re: automatic torque converter & flex plate
Astron boy :lol:
Sahin wrote:Astron boy :lol:
I thought you'd have dozens. :lol:
wagonist
Post by wagonist »
So, anything?
Or tips about who might be good to contact?
wagonist wrote:So, anything?
maybe Dstocks
It's a pretty standard Mitsi 7 bolt pattern. I've got a spare engine here I can get dimensions off if you want.
wagonist
Post by wagonist »
Could I come round sometime to get some measurements myself?
There's a few other measurements I need for my application.
I'm trying to get a custom flywheel made up & have the flex plate helps with getting that crank pattern correct (I have got a scanned image of the small "plate" that fits where the bolts go through the flywheel, but nothing's better than something physical ;) ).
Plus I want the starter ring to fit onto the flywheel.
Sure. Where abouts are you based? You know you can buy lightened flywheels?
wagonist
Post by wagonist »
I'm in Western Sydney.
Factory flywheel is no good to me as I'm not using FTO gearbox
wagonist
Post by wagonist »
Bennoz wrote:Sure. Where abouts are you based? You know you can buy lightened flywheels?
PM sent
wagonist
Post by wagonist »
Change of plans as I'm aiming to using a 6A13TT engine but still with FTO gearbox. As the clutches activate differently, I need to use an FTO flywheel.
suggestions where I can get one?
Fidanza do them, regular one and a lightweight one.
wagonist
Post by wagonist »
any idea of suppliers?
ive got several of them 2nd hand. Have been sitting on the shelf in the shed for a while, but should be OK. Must have missed this post before.
    wagonist
    Post by wagonist »
    even better, thanks. Sent you a PM
