Page 1 of 1
Power window fuse keeps blowing
Posted: Tue Mar 05, 2013 10:03 pm
by shadowarrior
The power window fuse of Mrs' Pajero keeps blowing. Could it be faulty switch? How come it works fine for a week or so after I put new fuse in if it's a faulty switch?
Haven't installed anything on the car which would affect wiring. Any idea? :\
Re: Power window fuse keeps blowing
Posted: Tue Mar 05, 2013 10:04 pm
by Taz
It will be one of the old skool gremlin powered window systems - and theyre probably pulling some kind of prank, or you've gone and fed them after midnight...
Posted: Tue Mar 05, 2013 10:06 pm
by Sahin
shadowarrior wrote:The power window fuse of Mrs' Pajero keeps blowing. Could it be faulty switch? How come it works fine for a week or so after I put new fuse in if it's a faulty switch?
Check your fuse mate :troll:
Posted: Tue Mar 05, 2013 10:10 pm
by shadowarrior
:facepalm:
Posted: Tue Mar 05, 2013 10:15 pm
by Daniel2019
Theres probably a short somewhere or you're using the wrong type of fuse me thinks.
Posted: Tue Mar 05, 2013 11:11 pm
by shadowarrior
12v 30amps... :\ displayed on the fuse box as well. Finding the short is going to be a PIA. I might look at the switch for any tell tale signs of burnt connectors.
Posted: Tue Mar 05, 2013 11:20 pm
by Sahin
shadowarrior wrote:12v 30amps... :\ displayed on the fuse box as well. Finding the short is going to be a PIA. I might look at the switch for any tell tale signs of burnt connectors.
Just put a 50amp fuse in there, she be right lol
if it catches fire just pull it out
Posted: Wed Mar 06, 2013 9:46 am
by fraz91
Probably find the window motor is on its way out, and is shorting somewhere inside the motor casing. Will be an intermittent short, as may require a certain bump to get it to work hence the week while it works and then it blows.
