New BMW using Mitsubishi parts as main components
FTO338
Post by FTO338 »
Yes thats right, everyone had been talking about the new BMW twin turbo e92 335i.
Its suppose to have lag free performance, which only one other car/model had claim, and thats Porsche 997 911 turbo.
I've got the following info from BMW.
Build to BMW specifications, the two small low-inertia Mitsubishi turbocharges provide air to three cylinders and operate together rather then sequentially.
Bmw specified that it wanted its turbines to tolerate high-heat operating conditions of up to 1050 degrees, more then 100 degrees higher then other turbos with durability equivalent to the life of the car.
It claims the special heat-resistant steel used in their construction is better then a ceramic turbine.
Imagine stick one of these turbo in a evo. :D
fto617
Post by fto617 »
hmm intersting
anyways, renault megane turbo use mits turbos as well...
i like me evo the way it is...
with a 2.3L stroker....i'm sure it'll rip their balls out 8)
past ride : FTO gpx with lots of bling bling
Current ride: EVO 8 with the MOST CARBON IN AUSTRALIA....206KW AT ALL WHEELS
Liquidity
Post by Liquidity »
that looks INCREDIBLY complicated. Not much room for bigger turbos, by the looks of it?
BorepYano
Post by BorepYano »
some volvo 760 turbos use a mitsubishi turbo as well.
have i ever mentioned that i hate volvos T_T'
FTO338
Post by FTO338 »
Well i was bored at work, so i thought i make this gif file of the just release 335i hardtop convertible. It can open and close the roof with an remote.
