Bjs turbo Version R fto
fto-007
Post by fto-007 »
Hi all thought id show off my 1998 Version R fto! I have had the car for around 9 years its still a work in progress but I will show you what I have done so far :D
The specs
Engine
6a12
JE 8:1 2618 Alloy forged pistons
* High Heat Ceramic Coated crowns, Moly coated skirt, Total-Seal Gapless Top rings, Lateral Gas Ports, Accumulator grooves.
Pauter Rods with ARP2000 Bolts
RPW custom high boost cams with cam gears
Ported and polished heads (flows 400hp @12 psi)
Full blue printed engine
Evo 8 injectors 560cc
De-valved intake
Water to air intercooler setup
Trust 13 row oil cooler
Wolf v500 computer
T28 turbo… for now
In tank walbro fuel pump working on surge tank and 2x bosch 044
Custom carbon fiber air box
Exhaust
Custom manifolds,
Custom downpipes,
Custom turbo intake pipe,
Custom turbo exhaust pipe
RPW extractors
Custom 3” cat back exhaust
Kakimoto muffler
3” resonator
Suspension and gear box
Tein coilovers
Tein camber tops
Upper front and rear sway bay
Exeddy cussion button clutch
Version R lsd
Brakes
Stock for now
Interior
Custom carbon fiber dash surround
Push button start
Custom boost guage mould
Custom oil pressure and air/ fuel ratio guage
Stereo
Alpine in dash dvd tv
Alpine 6 cd stacker
Alpine center speaker
2x Alpine mono block amps
2x 2ch Alpine amps
1x 4ch Alpine amp
Alpine 15” dvc type R sub
Alpine type x 3 way 6.5” splits
2x Alpine 6.5” type r splits
Alpine pxa-701
Alpine tv tuner
5.5” tv in boot
Stinger cable
Whole car sound deadened
2x optima 6 cell batterys
Body
Gpx side skirts
Custom carbon fiber mirror inserts
Wheels
Work emotion cr kai
Front 18x8.5 with +25
Rear 18x8.5 with +20
:cheers:
More pics!
fto-007
Re: Bjs turbo Version R fto
Post by fto-007 »
few more pic to come :)
Your boot set up looks f**king amazing!, are you running 0 gauge wire?
fto-007
Post by fto-007 »
more pic :evil:
That is a serious setup.
Love it.
fto-007
Post by fto-007 »
some more pic!!!! :cyclopsani:
fto-007
Post by fto-007 »
yeah thats 0 guage wire lol
Hey I recognize those plates.
I seen you a couple of times before, not given 2 thoughts about it.
Funny.
fto-007
Post by fto-007 »
It does'nt come out much done 25 000kms in 9 years...yeah i didnt want something that screamed look at me i want to be booked. :cyclopsani:
Looks very professional man. I am impressed.
fto-007
Post by fto-007 »
yeah i took my time with it.. took me 2 years to install the stereo the 2 moulds in the boot took over 130 hours of sanding i also rigged up a electric glass window to hide the nos bottle :twisted: it took me 24 hours to make the up and down pipes im very fussy with this car.
Astron_Boy wrote:Hey I recognize those plates.
Funny.
What were you doing in Lismore 8O
Looks deadly BJ!
phunkydude
Post by phunkydude »
So all these while you took those picture and keep it to yourself untill now. :lol:
fto-007
Post by fto-007 »
i hate showing half a job....looks like your rough prick :lol:
Very nice build, I like that you've kept the body clean as well.
So the big question, what sort of power is it putting out? :D
fto-007
Post by fto-007 »
it hasnt been for a power run as yet.. the turbo ran out of puff at 12 psi. before i started turboing it i wasnt going to build the engine i was just going to run small turbo and low boost...but now ive build it the turbo is way too small so theres no point flogging a dead race horse so to speak. im making a fuel surge tank up atm with twin 044's then a custom plenum with 90mm throttle body then ill put the big turbo and external gate was thing a gtx 3076r. atm it puts out 227hp atw @ 12psi mivec isnt turned on and cams arnt dilled in running at a very say tune atm. but all in all is running very sweet :D
evoman
Post by evoman »
Wow, this has got to be one of the cleanest FTO's I think I have seen.
Amazing build. Well done.
Personally - finish the engine work, take the contents of the boot out, chuck on some semi's and let her do what she was born and then bred to do :-)
xj265
Post by xj265 »
Mighty impressive!
Valandis91
Post by Valandis91 »
SLEEPER!!!!
I love it,
One thing, personally i wouldve sold your motor to someone like me as it has such a fresh bottom end (before you did anything)
and rebuilt an older engine!
Would've saved a bit of coin as well
