Bjs turbo Version R fto
Re: Bjs turbo Version R fto
Yes yes u did but in a way if most people could do it I'm sure they would hell I would just to scare the sh*t of myself overtime I drive it :D
everything about this car is so clean! good effort man love it
fto-007
Post by fto-007 »
Thought I would do an update its been a while :/ Ok went to dial the billet cam gears in and they have started to fall apart... the metal wasn't heat treated enough and they are falling apart :cry: they are in Perth getting fixed ATM and should be back next month fingers crossed :| Since then I have upgraded the front brakes with 356mm floating rotors with 8 pot calipers 8) upgrading the rear as well. I epoxyed in a pair of BMW M3 bonnet vents into the carbon bonnet and had it sprayed.. the colour is a little out which I will get fixed when the car is running 8)
fto-007
Post by fto-007 »
Bonnet
Fuckyeah :lol:
Would have to be the best built FTO in the world almost!
Those brakes! 8O
Sweet mother of 5 min toilet time.
Astron_Boy wrote:Those brakes! 8O
5 minutes? Please..
5 minutes? Please..
I'm a busy man.
5 minutes? Please..
I'm a busy man.
f**k 5 mins :evil: 30 seconds and that was with a little self romancing and lighting the candles to set the mood :lol: .
fto-007
Post by fto-007 »
They were 2k delivered full bolt on kit great company to deal with great product :)
I love those rims! That's what I want when I get around to doing mine 8)
fto-007
Post by fto-007 »
Upgrading rear rotors 260mm to 314mm 8) callipers have been power coated the same colour as the front with EBC red stuff pads installed and a custom calliper bracket made. Should be the goods :D
Does powdercoat have higher temp rating than, the brake caliper paint?
silverGPX wrote:Does powdercoat have higher temp rating than, the brake caliper paint?
Paint is rated up to 500 degrees. I would assume powdercoating would endure more.
fto-007
Post by fto-007 »
High silicone content powders withstand temperatures up to 1000ºF and offer superior durability when compared to brush and spray-on coatings.
8O
yotka
Post by yotka »
You are on this month's cover!! June 2013 FTO calendar.
fto-007
Post by fto-007 »
really? whats the link? :D
yotka
Post by yotka »
http://ftoaustralia.com/v3/viewtopic.php?f=1&t=27184
Go to the lulu link in the 1st post and select the preview link there and go to June :)
edit: It has the normal bonnet on it though.
vanadinite
Post by vanadinite »
what rear Calipers are you going to use?
