Was Rock_it & Sanjna's. now Daniel's New Ride
Re: Was Rock_it & Sanjna's. now Daniel's New Ride
You also may need to polish the wiper motor... after you've parted it out.
- rock_it
Which was my thought... Just use the guy I gave ya...Daniel2019 wrote:Will get an alignment done anyway. I get them done for like ten bucks. Thanks guys ill look into it.
There's a set of speedbumps in a block of flats that I deliver to and car scrapes almost always. Will raise 1-2cm and it should be fine, only very minor scrapes.
To wrap it the paint has to be perfect and its currently not at all. My guess is that they'd strip it, do roof rust anyway so I'm better off just spraying it.
FROR!Bennoz wrote:You also may need to polish the wiper motor... after you've parted it out.
Don't be silly, if I did that id make more money than selling it. Plus its not a "mint" version R.Bennoz wrote:You also may need to polish the wiper motor... after you've parted it out.
Replaced blue parkers with "clear" (slightly yellowish though ) bulbs.
No more obvious defectable bits! (aside from Apexi pod under shifty, illegal looking carbon bonnet)
- Cassf88
Can someone tell me why this thread doesnt have me as the first owner... 'was cassf88's' THEN Rock_it
- Shhtuart
Well whaddya know. I always thought the creative wing was basically just an adjustable topmix wing. Apparently not.
Result!
Result!
- bjk
- Totes
And it was hiding on the website the entire time.Daniel2019 wrote:Well whaddya know. I always thought the creative wing was basically just an adjustable topmix wing. Apparently not.
Result!
- shadowarrior
- Tightarse
Damn it! Now I can't call it a shopping trolley handle any more :/
Replaced tip shifter at Dwayne's and picked up ignition failure sensor for tacho + picked up a few bits with a mate for his car too.
And made it home.....
Only just, had to stop oncedstocks wrote:And made it home.....
For a poo?Daniel2019 wrote:Only just, had to stop oncedstocks wrote:And made it home.....
To not blow a head gasket...PHIL069 wrote:For a poo?Daniel2019 wrote:Only just, had to stop oncedstocks wrote:And made it home.....
So yes
- rock_it
How hot did she get?
Again, no higher than slightly under 3/4.
- kiz
- SA Coordinator
Oh, I would've pulled over for a sneaky in the bush... why not ey..PHIL069 wrote:For a poo?Daniel2019 wrote:Only just, had to stop oncedstocks wrote:And made it home.....
1998 Mitsubishi FTO GPVR AERO
