Res' 6a12m coupe
Res
Res' 6a12m coupe
Post by Res »
hey, I'm Res
Been in the lancer community for about 5-6 years now, recently scored myself a 6a12m motor to put in my CE coupe
I plan to get it in by late february 2014.
as far as the coupe goes it has almost everything suspension and braking that can be done done.
now all it needs is power which is where the 6a comes in.
as far as specs go;
BRAKES:
~Evo3 front twin pot calipers
~276mm RDA Gold rotors (slotted and dimpled)
~EBC greenstuffs
~Evo3 Rear single pot calipers
~260mm Rear discs
SUSPENSION:
~BC BR (golds) Coilovers 7/5kg rates
~Evo4 21mm front swaybar
~Fto 22mm(pt-24mm) rear adjustable swaybar
~Ultra Racing 2pt front strut top brace
WHEELS + TYRES:
~Enkei RPF1's 16x8+38
~Kumho KU36 simi slicks 215/45/16r
~Enkei Vrx's 15x6.5+38
~Kumho Ku31 radials 195/50/15r
(soon to have full set of RPF1's after swap is done)
MOTOR:
~Evo4 thick core full allu radiator
~Slim Fans
~4g93 block and head
~4g94 intake manifold
~TOG headers
~DP aluminium Cold air intake
~4g92m (cyborg) manual gearbox
~Cusco catch can
INTERIOR:
~Battery to boot relocation
~Recaro bucket seats (m21)
~Momo steering wheel
~Slimline quick release boss hub
~UK fully adjustable short shifter
~Oil temp and Oil pressure gauges
~Wink mirror
~Eonon dual din Head unit, (all the good stuff gps, ipod, cd, USB, blutooth, SD card etc touch screen and buttons)
~Response speaker system.
WAITING TO BE FITTED:
~Goodridge braided brake lines
~HEL braided clutch line
Res
Re: Res' soon to be 6a12m coupe
Post by Res »
6a12m engine being delivered this arvo, then all i need is to do a good major service and in it goes
-Timing belt
-water pump
-HD clutch
-scrub and a bit of paint
then in she goes as soon as thats all done.
my current motor is at 360,000kms and feels like death at the moment, i could have fixed the issue with it but i figured bigger and better is the way to go
RPF1 love! Will look swish when they're on all corners. But why no front pics!
Res
Post by Res »
yeh cant wait to have RP's on all 4 corners, have to buy them slow because of the 500$/corner with a semislick brand new
front is a bit meh at the moment, just 100% factory again, it USED to look neato
this is an old pic when i head my old custom made headlights.. sorta miss them a lot, but i will build a new set sometime soon
Looks pretty mean. What happened to the headlights?
Whats a 6A12m?
Welcome!
what u transplanted
Ah mivec... right :lol: :lawso:
Nice car, I do like those custom headlights!
Res
Post by Res »
Daniel2019 wrote:Whats a 6A12m?
its the general designation of the 6a12 mivec (m for short) not the proper engine code but it makes it easy to know which one you are talking about
we also use 6a12g for the opposed orientation one from a galant saves confusion
or 6a1X if its a hybrid/frank motor built from the 6a13+12
____________________
so 6a arrived yesterday, didnt get much time to work on it as it was quite late
today i ordered a bunch of parts for its major service
new HD clutch and TOB, new timing belt and tensioners, cam and crank seals, water pump, throttle cable, all the wiring diagrams and workshop manuals for the 6a1X's.
things i still need to get are A/c pump and bracket, power steering pump and bracket, serp. belts, throttle body, spark plugs, and some fresh gaskets for the heads
Looking good Res,
What happened to your headlights?
And, what's wrong with the current motor?
360,000km 8O
Res
Post by Res »
Headlights i sold on as i was parting out the car at one stage earlier this year
And motor has a massive lag then surge in low rpms which makes it annoying to drive
Checked everything asside from timing, fuel filter and O2 sensor, but has prompted me to buy a new engine at its age
Yep good decision to recondition it, definitely. I rebuilt mine completely but that's a different story.
Like having "its all brand new" in the back of my mind :cheeky:
Good luck with it!
Res
Post by Res »
so, today i cleaned about 80% of the built up oil sludge and gunk and dirt and mud and leaves off the engine, ran out of the degreaser cans i had and dish soap and scourer was only going so far
found out im missing the 6 or so bolts and 2 nuts that hold the intake manifold to the splitter section so need that before doing the swap
other than that, next time i see the motor i will be confirming if i can use my cyborg short ratio gearbox with it, all signs look good but need to check,
i didnt want to take any chances, some say the 6a12 is a bit slow and lacks torque in the low end as per a norm for mivec engines, so no chances taken i want to use the shorter cyborg ratios to make sure i have plenty of torque in the low end to satisfy me.
now i just wait till the new gasket kit to come and clean it some more, reseal it, figure out the wiring and bam it goes in as soon as thats sorted so not long now, maybe by months end or mid next month depending on the time off i get to work on the motor
I want a cyborg :(
I know the feeling of missing bolts! Haha. When I went to pick up and pay for the engine I got, they discovered it had already been partly stripped of a few things like that. Fortunately could just reuse them from my old motor.
Progressing quickly! 8)
Res
Post by Res »
first lot of 3 deliveries of parts arrived today
Tbelt, seals, water pump, and throttle cable
then clutch tomorrow, then all i wait on is gasket kit and it all gets started
res wrote:things i still need to get are A/c pump and bracket, power steering pump and bracket, serp. belts, throttle body
I have all this man
Res wrote:found out im missing the 6 or so bolts and 2 nuts that hold the intake manifold to the splitter section so need that before doing the swap
And this
Res
Post by Res »
how much you want for it all man, also where location?
(no longer need throttle body or cable)
just bolts, A/c compressor and bracket and powersteering pump and bracket
