Engine Rework
Taiwo
Re: Engine Rework
Post by Taiwo »
http://pages.ebay.com/link/?nav=item.vi ... 62&alt=web
I found that. So I will just get an harness that for it then
"Is that a supra???".
"What's a Mitsubishi FTO?"
Re: Engine Rework
nooooooooo
first off, without the 4 pin alt, your mivec wont work (cue "fix my mivec dwayne")
the ecu's are the same whether manual or auto, as dan said the auto ecu (TCU) is seperate and plugs into the ecu.
do it properly or dont bother - youre just inviting a whole lot of pain and frustration... you are trying to piggyback systems that just werent designed to do what you want them to do... who knows what kind of errors you are gonna throw.
hit up dwayne (dstocks) and get the right parts you need.
Taiwo
Re: Engine Rework
Post by Taiwo »
SchumieFan wrote:nooooooooo
I am getting a ECU and custom intakes out of a version R. I am just after wiring harness and alternator which I will get soon from a GPX. I have done some looking around and some research since I posted last message :D :D
So I am avoiding the hard road of trying to mix and match and stuffing up this engine.
Thanks for the warnings.
Mivec swapped gx
Re: Engine Rework
Post by Mivec swapped gx »
I have a mivec swapped gx and it seems to have the gr ecu in it running the mivec engine any idea how this is possible
Re: Engine Rework
What's the ECU part number?
