bwhahahahahahahahsilverGPX wrote:it would suck if some kid came along and pulled it off though!
where does your mate live?
Hi Guys,
Thanks to everyone for their contributions and patience during this start up phase.
We are basically ready to dispatch everyone's orders, but before we start sending the kits out, I just want to highlight some important application notes and applicable drying times, that weren't mentioned in the Indiegogo campaign.
So the main things you need to consider are the drying times and application temperatures (more important now winter is approaching):
The recommended cure time is 72 hours at an ambient temperature of 20°C
Surface temperature should be above 10°C and less than 35°C.
Do not apply if rain is imminent.
This means after application you shouldn't expose the surface to water or rain within 3-5 days or it could soften the wrap and you'll end up with a bubbles and peeling. Also, if you apply in cool temperatures, the cure time will be longer.
Now, we know not everyone can be without their car for 3-5 days in case it rains and we're not looking to take your hard earned cash and ride off in to the sunset, so, we can offer you three options:
We can offer you a full refund for your Indiegogo contribution... or if you're still keen,
We have been developing a solvent-based alternative which is weatherproof in 5-7 hours (instead of 72 hours), is more durable and easier to peel off. However, the solvent-based Liquid Wrap is not going to be available until June.
We can also still send out the water-based Liquid Wrap if drying times are not an issue.
With all that said, please let us know by return email how you wish to proceed.
Thanks again for your support and we apologise for any inconvenience.
Cheers,
Heath Taskis
Founder / Manager
Evolved Body Coatings
m +61 403 966 098 | e heath@evolvedcoatings.com.au
w http://www.evolvedcoatings.com.au | http://www.ebc.sc
