Sunroof, Colour matched interior?
- mezje
Hey guys,
Was sussing out FTOs and I cam across this: http://www.ebay.com.au/itm/Sports-Coupe ... 25a21e5fa8
Rims aside, I quite like the veilside body kit, especially the rear bar and wing. However I was wondering is the colour matched interior and sunroof stock?
I think I would be ditching the colour matched stuff pretty quick if I were to buy it... Not a fan!
EDIT: Looking at http://www.myfto.co.uk/fto-colours.htm, seems it isn't a stock colour either...
Re: Sunroof, Colour matched interior?
Rims are aids.. veilside kit also looks aids in my opinion.. full P plater spec!mezje wrote:Hey guys,
Anyway, sunroof looks factory but can't really tell from photos. If it doesn't have the bonnet lines continuing onto the roof then its factory. If it does, then its aftermarket. Non factory sunroof models had those two lines continue to the back of the roof, and sunroof models from factory had a flat roof with no lines. For reference, see photos of my sunroof. Mine had no sunroof from factory so it has the two lines on the roof as well as my aftermarket sunroof.
Color matched interior is not factory and probably looks like sh*t in person.
And nope, not factory color.
- mezje
Thought not, weird the engine bay looks like the same colour, no idea why you'd spend so much on a respray to that colour.Daniel2019 wrote:Rims are aids.. veilside kit also looks aids in my opinion.. full P plater spec!mezje wrote:Hey guys,
The car has likely been thrashed anyway... 'Vtech'.
While I have your attention I was also looking at: http://www.carsales.com.au/private/deta ... 7313/?Cr=1
Reckon those dents on the rear panel would 'pop' out? How much would I be looking at for a fix?
I think you'll find that color in the engine bay is the same as the imperial red and the car has been sprayed a color that is kinda close on the outside, that's why it looks like it's been done, although hard to tell without seeing it in person.
That silver one looks a bit hectic spec too. big mitsubishi stickers on the wing
Has had a front ender also. Paint doesn't match and the bar doesn't align, and is missing the mitsubishi logo. Does appear to be a genuine facelift though as it has the bar and steering wheel. BUT, can't see the 5th gear on the dash but listed as 4 speed auto (have a story about that... lol) If you can get the japanese VIN then we can check if it's a facelift or not. Has passenger's airbag though so I would assume it's genuine but very easy to check if you can get me the vin number.
As for dents, no idea
Decent price if it's a genuine facelift but does need a bit of work.
Veilside kit in Australia is usually a pretty crap fit. Check the joins between panels are decent in person.Im guessing they arent.
The 2nd one looks OK but not fantastic. Has drivers airbag and has the facelift bar. This backs up the 1999 claim. This also means roof rust will not be an issue (it is in pre 98 models).Few shopping trolley dents in a couple of pics, but looks straight. Fairly stock, so not as likely to be thrashed. Oh has a broken console. But worth a look in person. As Daniel says, check for respray. Lack of stickers on the back of the car will back this up.
- mezje
Thanks for that, I would definitely give it a good look at, seems there are a few FTOs being wrecked in VIC with consoles in tact, some on eBay too, apparently it is a common problem.dstocks wrote:Veilside kit in Australia is usually a pretty crap fit. Check the joins between panels are decent in person.Im guessing they arent.
Those Mitsu stickers on the spoiler would definitely be going... And the decal on the front replaced.
http://www.carsales.com.au/private/deta ... 1459/?Cr=2 This one looks a lot better for the price but knowing rust won't be an issue would be good...
Sticker on boot of that one is incorrect. It's a GPX. Mivec because the oil cap is on the driver's side. Which is weird because as far as I know, that's a GX interior trim and paint color, which is facelift non-mivec.
I reckon that one has had a Mivec swap like my car. Again, VIN would help.
- SchumieFan
Silver 1 is a genuine face lift, can see the passenger side air bag
Wasn't that optional in pre-facelifts too?SchumieFan wrote:Silver 1 is a genuine face lift, can see the passenger side air bag
Yep, both drivers and passengers airbags optional on prefacelift. Having said this you rarely see the passengers side ones in pre facelift (not sure ive ever seen 1).
Yup.. just looks like that front bar has been re-done so may have done facelift swap. Doubt it, but eh. VIN to check for sure just incase.
- mezje
So the one I was looking at is in fact a GX, no Mivec has kinda put me off but the car is so clean and a nice low amount of K's...
http://www.carsales.com.au/private/deta ... AD-3301459
My car should be sold by next week
- rock_it
The interior is out of a 97+ model as well ... Same as Bobby ... And SRS Passenger airbag ..Daniel2019 wrote:Wasn't that optional in pre-facelifts too?SchumieFan wrote:Silver 1 is a genuine face lift, can see the passenger side air bag
I think in earlier years pass SRS was an option, but in later models it was standard... But I am no guru ...
That one has a MIVEC engine. Has been swapped.
