Hi gang
Just bought my first FTO.
Is a 1995 GPX.
Not sure if this is standard or an issue, cannot find any info googling it.
When i turn the key off, and even remove the key, the engine continues running until i push the brake pedal and then shuts down.
The bloke i bought it of said it was doing it when he bought it and had no idea if it was some quirky idea or a fault.
Any info much appreciated.
Need to push brake pedal to turn off car.
- getonit
- rock_it
Re: Need to push brake pedal to turn off car.
Never heard of that one...
Push the brake to to start, yeah, but not to turn it off...
Nope, shouldnt be doing that. If you have a tiptronic, you often needto have the brake on to get out of park, but nothingwith respect to the ignition.
Sounds like someone might have wired in a turbo timer.
If you remove the key and leave it running does it turn off by itself after a bit?
Funny you say that. I was thinking that myself a few minutes ago.
- spetz
Does it have a remote start alarm system?
They do that as well quite frequently
- getonit
No turbo timer, naturally aspirated model.
Has an immobiliser.
Maybe someone stuffed up the wiring of that? Or thought it would be quirky to do just that.
Anyway, daughters car, and she thinks it's cool?????
Has an immobiliser.
Some alarms/immobilisers have a turbo time feature.getonit wrote:No turbo timer, naturally aspirated model.
Has an immobiliser.
It doesn't need to have a turbo to have someone think it's "cool" and wire it up.
