Bjs turbo Version R fto
- fto-007
Re: Bjs turbo Version R fto
The car has been 10 years in the making lol 2 years for the engine alone. .
- Kustom
- ZFL45H1
Epic build.
Great work.
Great work.
- ObsidianRadio
Wow. Wow. Wow. Wow. Wow!
Very nice work man, looks schweet!
- fto-007
finished speaking with my tuner... recommended to run it on race e85 and should make around 550hp at the wheels and rev to 9000rpm his also setting up launch control and traction control (boost over speed)
- bjk
- Totes
That's gonna be damn quick. Vids when it's up and running!fto-007 wrote:finished speaking with my tuner... recommended to run it on race e85 and should make around 550hp at the wheels and rev to 9000rpm his also setting up launch control and traction control (boost over speed)
- Kustom
- fto-007
If it gets good traction I want to get in the 11s if not lower. . .
- ZFL45H1
- fto-007
oh yeah ill strip it running slicks
- ZFL45H1
- fto-007
Hey just an update, had it tuned the intercooler was restricting the flow so i removed the water to air setup and installed a new 600x300x100 core air to air intercooler with 2.5" feed and 3" intercooler pipes. Bought a new oil cooler and mounted it under the drivers side wheel arch i made an air duck up and removed the spot lights for air flow and the other side ducted into the air filter air flow souldnt be a problem now just have to tidy up some small things and its finished just an air box, tidy up the air ducts, maybe methonol injection, and i have ordered a carbon fiber bonnet to help remove some of the heat, wrap the intercooler pipes to prevent heat soak as well
Looking good there!
- spetz
Intercooler looks awesome, keep up the great work
- den0va
Soo clean! O_O
- aza013
- NSW Coordinator
That scares the sh*t out of me seeing a car jacked up by the tow hook and nothing more under it .
But other than that love your progress.
I think its at the crossmember.aza013 wrote:That scares the sh*t out of me seeing a car jacked up by the tow hook and nothing more under it .
- Kustom
- fto-007
just a couple of pic...new carbon bonnet, new intercooler, new piping and bov
