Let me Re: Introduce myself
Re: Let me Re: Introduce myself
Wait a second...... Stock ECU flashed?
syntax
Post by syntax »
Vectose wrote:Wait a second...... Stock ECU flashed?
yes sir. 1996+ is flashable (well the 7202H Based Board)
How do u tell what board you have?
silverGPX wrote:How do u tell what board you have?
Yes please share
syntax
Post by syntax »
There is no easy way to tell. Im sure the MDXXXX number is different but i dont know which is which.
The semi easy way is to connect pin 79 and try to read it with Tatrix OP2+ECUFlash/MMC Flash and hope for the best.
The hard (for sure) way is to open the ECU case and see if the processor has MH7202F on it.
Is it just Phillips head to take the case off?
Humm interesting. I wonder if it would boost up my numbers a bit :? May be interesting to try.
I would like to hit the 150 before I move to other power options.
