BJK's 6A13TT FTO
Re: BJK's 6A13TT Money Pit
Sahin wrote: Tue Jan 16, 2018 9:04 am So nearly $1000 on stuff you don’t really need?
Only if you consider heat management non-essential...
I've spent money on stupider things! At least these are both functional. :lol:
The EVO 5/6 rack has the lines aimed differently. Clears some space at the rear.
So. Some updates.
Got my manifolds and rear turbo housings back. $500 all up.
VecTec arrived on Tuesday and got straight to work.
Tidied up the horror that was battery acid and rust.
Serviced this bitch and Rob was chuffed it was tensioned right on the test run. :lol:
The Mamba tee to fit both the pressure sensors for stock and the gauge.
Back together.
FTO sandwich plate and clutch kit on.
Gearbox on.
Brake distribution block/prop valve relocated and lines redone. Just a couple fittings to do.
Rob's been looking at the wiring today, will likely splice things from the VR4 loom into the FTO one. Need some longer bolts for the Evo 6 steering rack since it mounts differently.
Another thing that we'll probably do is use a front housing of the rear turbo with the associated wastegate actuator rod. Rod will need to be lengthened and a few washers and a longer bolt for one mount point, but as an alternative to making a bracket it could be a relatively simple fix.
Next week should hopefully see this in the bay. :bounce:
mezje
Post by mezje »
Very nice, they really are so similar to 6A12s in look, seeing the belt and water pump giving me a bit of PTSD lmao.
Can't wait to see more posts and it finished.
mezje wrote: Sun Jan 28, 2018 10:34 pm Very nice, they really are so similar to 6A12s in look, seeing the belt and water pump giving me a bit of PTSD lmao.
Just a big GR engine with some turbos :lol:
Got the brakes preliminarily bled this afternoon, no leaks from the new hard lines so that's sweet. Rounded nut on the passenger rear meant we couldn't get the new HEL line on, will have to take to a shop to get sorted later, but it's still braided at least.
Nice work man, gonna be sweet. For the brake line, me and Matt had to buy a “stillsons” to get rounded nuts off when we worked on his car..
Fuckn stillsons. Haha
Sahin wrote: Mon Jan 29, 2018 9:03 am Nice work man, gonna be sweet. For the brake line, me and Matt had to buy a “stillsons” to get rounded nuts off when we worked on his car..
Yeah, a bit too much f**king around for Rob to do while he was here. Just had enough time to do everything important. :lol:
Man, that week just flew by. I'll try to keep it concise.
Unlike the FTO, the Evo 6 rack doesn't have a bush and clamp on the pinion side, it just bolts straight through the rack itself. We grabbed the bolts we needed for that, & for extending the actuator rod, as well as washers for the same and also spacing down the gearbox side for like $10. (Annoyingly didn't get new tie rod ends with the reco'd rack, so had to grab a couple off eBay. Glad I negotiated a slightly better price even more now lol)
Got 3/4 of these on.
Secured the loosest brake line with some nutserts and these handy clips.
Wrapped the new shifter cables in DEI titanium heat wrap.
Here was the first prototype for the rear-compressor-housing-on-front-turbo mod. As you can see the bolting points for the actuator bracket are mostly the same except that they require some washers and a longer bolt to secure it to the housing. Rob bent the rod where it needed to go, and then we had the rod extended. I think we asked for 45mm, but it ended up being slightly too long and was too loose. So we used a nut in place of some washers and moved them across to bring the actuator a little further back again.
Note: getting the oil and coolant lines for the turbos bolted on while the turbos are still connected to the car is a nightmare lol.
New paper gasket for the compressor housing since the old one disintegrated after removal.
This fucker in the bay.
Firewall doesn't need touching for the rear turbo to clear, but it is squeezy around there. As others have already confirmed, rear dump is useless due to interference with the rack. I'm going to be having a custom piece made up. (pray for the fab guy)
And how the front turbo sits.
The high pressure P/S line that we had made up. Labour was fuckn expensive but the shop was nearby and since we needed to go back and forth three times it was a better alternative to driving up to the other side of the city.
And how she sits. Nice and away from everything else.
Mishimoto thermo fans in. Need to get a switch done as the VR4 usually has a controller in the bay, and in its absence they are switched on 24/7. Better than the alternative but not ideal.
And basically all plumbed up and fluids in. Those on facey will have seen the start-up vid. Conveniently the other Rob I got the airbox off sent the intake pipe as well, which I didn't think I would require, but for getting the air from the MAF to the TB has proved to be useful. Will roll it down the drive and then it'll run enough to get into the street and on to the tow truck.
Fingers crossed for smooth sailing once all the piping is done up!
For those curious, counting labour from VecTec and an estimated cost for intercooler and exhaust piping, the grand total comes to about $9278 from what I've been keeping track of.
mezje
Post by mezje »
Love the pics, price honestly better than I expected! Should be a lot of fun when it is done.
Looks like Rob did great work.
FTODreams
Post by FTODreams »
No problem Billy! Thought you could use the pipe as well as the box!
mezje wrote: Mon Feb 05, 2018 11:47 am Love the pics, price honestly better than I expected! Should be a lot of fun when it is done.
Yeah, all the pre-planning meant I had a pretty good idea about what the final figure would be. There were some expensive additions though, notably the Evo rack, which for all the components will have costed like $775 at the end. The HPC was a little more than I thought as I went about a bit differently than I'd first planned for. But better to have done it now and see the benefit (hopefully lol). The spare turbos I bought also ended up being a good investment as the ones that came on the engine were significantly more worn.
And yah, VecTec delivered the goods. Even painted that spot of paint I scraped off the front bar in Broken Hill :lol:
FTODreams wrote: Wed Feb 07, 2018 10:37 pm No problem Billy! Thought you could use the pipe as well as the box!
Very useful! haha. Although the 6A13 MAF is slightly bigger diameter so it doesn't quite fit on, but close enough! Might wrap a little tape around it but it doesn't need to make it very far at all.
Good work both of you.
I'd say 'progress' but it's just moved from one place to another. :lol:
f**k you
Sahin wrote: Thu Apr 05, 2018 8:04 pmf**k you
Also not much more progress. Got some factory VR4 feed pipes most of which should work. Meanwhile nothing significant from the shop where it's been, should have anticipated this a long time ago and taken it elsewhere but I was stubborn :roll: have a couple places in mind so we'll see who can take it sooner preferably.
That's cancer Beej. Go borrow a car trailer!
Bennoz wrote: Mon Aug 13, 2018 3:46 pm That's cancer Beej. Go borrow a car trailer!
I'll just strap it to my housemates Triton. Dash Cam Owners 'She'll be right' album here I come!
Re: BJK's 6A13TT FTO
So a bit of progress in the last few weeks. Took it to another shop (the same that welded up my captive nut a while back), and even though he's still having to do bits at a time at least it's getting done! The exhaust side of things will be finished (except for ceramic coat) by the end of the day, and then it's onto the intercooler pipes, airbox, catch can etc. Won't end up using any of the stock stuff, with the aim of making it the best it can be with the available space.
Here's a couple pics I grabbed when I was down this afternoon.
It's all looking good :D
