You're as bad as Craig with your 'fleet' of carsAstron_Boy wrote:Makes me want to dig out my VW Bug from storage and fix it up. (again)
The mighty Mini
Re: The mighty Mini
- ObsidianRadio
Re: The mighty Mini
*Pops mini*
Re: The mighty Mini
nice
Wanted a mini before i got my FTO, but the price tag was still ridiculous, was like f**k that im getting an FTO
Re: The mighty Mini
Nice touch.ObsidianRadio wrote:*Pops mini*
I used to have 10 cars at one point.Bennoz wrote:You're as bad as Craig with your 'fleet' of carsAstron_Boy wrote:Makes me want to dig out my VW Bug from storage and fix it up. (again)
Re: The mighty Mini
Hot Wheels?Astron_Boy wrote:I used to have 10 cars at one point.
Re: The mighty Mini
Nope, drive-able.
I haven't counted my Hot Wheels collection.
- aza013
- NSW Coordinator
Re: The mighty Mini
Sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet !
So when is the working bee on it?
Re: The mighty Mini
It's already begun!
Re: The mighty Mini
man i wish you could like comments, im to use to fb ill admit i actually looked for the like button for a few seconds before i realizedTaz wrote:nice
Re: The mighty Mini
Ehh, can't be assed...adzski wrote:man i wish you could like comments, im to use to fb ill admit i actually looked for the like button for a few seconds before i realizedTaz wrote:nice
Gen Y, etc.
- bjk
- Totes
Re: The mighty Mini
We need an "Astron" smilie, pronto!Astron_Boy wrote:Ehh, can't be assed...adzski wrote:man i wish you could like comments, im to use to fb ill admit i actually looked for the like button for a few seconds before i realizedTaz wrote:nice
Gen Y, etc.
Re: The mighty Mini
No-one has that much download.
Bennoz, what are the tech specs on the Mini.
Which engine, carbs, etc.
No details, need moar!
Meanwhile, guy 5 houses down has a little blue number with white stripes running over the top, I assume its an 80s model given the interior.
Not a bad bit of kit.
Re: The mighty Mini
Its a 69 Mk I Cooper S.
Was the 1275cc solid block, bored as far as it will go (offset bored no 1 & 4 outward so we didn't go through the cylinder walls lol) to 74mm (1.4L) with 74mm Omega pistons. 45mm side draught Weber carb, big bore LCB style extractors & 2" exhaust (straight through lol)
She runs 11:1 compression, the biggest valves we could fit in (from a Toyota lol) with huge porting work, Kent 296 rally cam, 1.5:1 ratio alloy roller rockers, vernier double row timing chain, central oil pickup, 4 speed full syncro box with semi straight cut final drive & cam & pawl style LSD. Hardy spicer type drive shaft joints & 7.5" Moke brakes with braided lines.
On the inside, its restored original, new carpets, seats & panels, except the drivers seat, which is a fibreglass Marsh race seat with 4 point harness. Also has a 4 point Bond roll cage (padded for legality reasons) and I kept / restore all the old English Smiths analogue instrumentation.
The list is a whole lot longer to go on here though Makes about 130hp at the flywheel, more with the nos on
Re: The mighty Mini
That's a sweet setup, would love to hear what it sounds like.
Always liked the minis, always wanted the clubman personally, but so few and far between unless you spend the cash. Much like a good VW Bug meanwhile...
- spetz
Re: The mighty Mini
That does not look like a K20?
- koolio1234
Re: The mighty Mini
Looks very clean, have you done anything to it suspension and brakes wise? They are meant to handle well stock from what I hear.
Re: The mighty Mini
Front suspension is all old Jag running gear, camber & castor adjustable arms, with the subframe being converted to rubber cone with Hi-lo adjustables from the old hydrospastics. Also has Spax adjustable shocks & poly bushes. Also has Kmac rear sway bar & camber adjustment plates on the rear. Brakes are the bigger 7.5" off the Mokes on the front, has the finned drums on the rear & and an aftermarket brake booster unit
Re: The mighty Mini
New alloy radiator arrived today. Gotta mount the thermo to it.
Re: The mighty Mini
Certainly getting some love.
- Supplanter
