getonit wrote: ↑Fri Dec 21, 2018 10:56 am
What about relocating the fuse box for air box space?
I can send you a decent length section of facelift harness.
Thanks for the offer Jim, but I'd rather not fiddle too much with the wiring side of things. Will make it easier when it all changes chassis lol.
adzski wrote: ↑Wed Dec 26, 2018 1:08 pm
Looks awesome mate., great work
Cheers man, at least it looks good for all the money I'm throwing at it
Misfiring cylinder was diagnosed as one of the new aftermarket lifters being physically too large, holding a valve open, and preventing it holding compression. Took it around the block after that was all fixed, but it was spiking to the ECU's boost cut at 14psi or so, which was later found to be some vac lines that had not been plumbed in yet. Apparently it's still cutting a little, but not as bad as before. Now it's basically just registering it and alignment stuff and trying not to get defected driving it home!
My budget blew out (Bennoz chortles heartily) but it will be worth it, and god it sounds good. Have some pics of the finished product. Pure weld-porn.
Bennoz wrote: ↑Thu Jan 10, 2019 10:04 am
I love how you think it's 99% finished
My car's not finished, drove it as a daily for years with the 6A13, but it'll never be bloody finished
There's always something...
99% finished stage 1 of infinity stages
But yeah, definitely not "done"... Still want some real Recaros, was gonna pick up a cheap Galant box for future use but not sure if I'll have the cash now haha. Then there's the old silver FTO. Cars, amirite?
spetz wrote: ↑Sun Jan 13, 2019 2:10 am
Looks really nice BJK, looking forward to more updates and pics
aza013 wrote: ↑Wed Jan 16, 2019 3:54 am
Looking good
Danke, danke.
I've had the car back properly since Friday evening now, a whole lot of things got tidied up on the suspension side of things which is good, and they managed to reverse fit the offset castor bushes so it's pulled the wheels back a bit. Still a couple degrees above stock but better for clearance whilst still maintaining the performance benefit.
As always there's a cacophony of interesting noises, although they seem to be much more pronounced at low speeds. Otherwise everything else appears to be running as normally as it can. Have oil pressure, it's getting up to temp but not overheating, the weird boost cut I think is just a product of coming off throttle too quickly (and the pedal is a bit sticky for the first couple cm or so), still builds and holds it fine.
Gave it a cursory scrub-up since the paint is farked anyway, but she looks alright for the camera
FTODreams wrote: ↑Tue Feb 12, 2019 2:02 pm
What are those recaros from? Also really good progress, looks amazing and im sure is fun to drive.
It's a hoot, great usable power and still handles as well as I remember, despite the extra weight up front.
I actually have no idea re: the seats I can only assume they're the real deal as I don't imagine Tim would got them otherwise, and they're a lot more comfortable than the old reps that this car came with.
Well the little bastard decided she'd overheat today as karma for me believing it never would. Hot-ish day and sitting in traffic pushed the water temp to about 2/3 before I could pull over, which I had to do twice on the way home. Bit disconcerting considering the thermo fans are always on, but I wasn't too keen to see if they could actually pull the temps down with enough time. Might actually have to get a coolant temp gauge as well just so I have something a little more accurate than the stock one.
Made it to and survived All Japan Day 2019 though, so that's a plus.
Turns out my thermo fans are misbehaving, potentially what caused it to overheat the other day. Instead of being off to start with and turning on when the car gets hot, they're doing the opposite. They'll switch on as soon as you turn the key past accessories, but I noticed while it was idling that they randomly died and didn't come back on. If I turn the car off, and turn the key partway again they'll come on, but turn off as soon as the engine is actually running. Vectose reckons maybe the signals/relay are reversed on the ECU side of things as that's what they're connected to, sussing that out atm.
The über-rice AB style fake-carbon bonnet maybe seems to be helping when the car is actually moving, but it didn't really have too much issue with that before either, so hard to tell. Either way I've got an alloy china-rad on the way that's taller as well having a 50mm core, which a) hopefully fits, and b) solves that side of things. Also grabbing an in-hose temp sensor fitting and an additional VDO coolant gauge so I can actually see what the hell it's doing
Really wanna make it to bonfire this year but f**k the weeks are just disappearing and I'm feeling less ready by the day...
Maybe the ac pressure switch is f**king with the fans? Be worthwhile hitting the relay and coolant temp sensors with a multi meter and make sure they are playing.
Gee, been a while here. Fan issue was just backwards signals probably due to lack of factory fan speed controller, haven't seen it climb past 100deg even with standard size rad in there. Then alternator carked it around the same time as it threw a CEL, started cutting out at W.O.T., hovering around and maybe slipping. Bunch of usual infuriating old import sh*t.
Booked in for a run on a dyno to see if it's the clutch or maybe in fact the injectors or just the ECU throwing a fit with all the big pipes. Can't tell if the cut is really a new development or if I just never had put my foot to the floor for long enough before.
