It's Astron talking to someone from GenY. Of course he's trollingDaniel2019 wrote:Astron cant tell if trolling or serious..
Daniel's Rookie DIY FTO Build!
- fraz91
- Hair-do
Re: Daniel's Rookie DIY Engine Reco!
Shouldve known.fraz91 wrote:It's Astron talking to someone from GenY. Of course he's trollingDaniel2019 wrote:Astron cant tell if trolling or serious..
Had a go at getting the rocker cover off, unsuccessfully. Used the guide in the DIY section, made sure I disconnected everything and had all the bolts out but it's still sealed on tight. Does anyone have suggestions on how to remove the cover? My guess is that its been sitting lifelessly for a while. Tried using a rubber mallet to "tap" while pulling the oil cap, still nothing. Im tempted to use a screwdriver and hammer it into the seals to pop it off, but dont want it to slip under and hit anything inside the engine or crack something thats not meant to be cracked, etc. Not a lot in the user manual that's different to the guide on here.
Any suggestions?
Any suggestions?
Use a bigger hammer
If only that were the answer.. Im tempted to hook up the engine jack and try and lift itBennoz wrote:Use a bigger hammer
Use a crowbar it's perfectly safe (no troll)
I dont think I have a crowbar small enough to get in between the top cover and bottom housing/cover, nor will a screwdriver fit in to pry it up. Tried lifting it with the crane, too. No luck, the engine just got lifted along with the stand. Also, would a crowbar not damage the gasket?Sahin wrote:Use a crowbar it's perfectly safe (no troll)
Get a new gasket you stinge
Aren't you rebuilding it?
Trust me, use a bigger hammer.Daniel2019 wrote:If only that were the answer.. Im tempted to hook up the engine jack and try and lift itBennoz wrote:Use a bigger hammer
I am, and im doing it on a 17 year old student's budgetSahin wrote:Get a new gasket you stinge
Id rather not pay for sh*t that I already have hahah. Theyre about $60 arent they? I know that sounds stingy but if I just break sh*t all the time that doesnt need to be broken then its all gonna add up real quick. Not to be a tight ass but itd be stupid to spend more than is necessary on a reco.
Haha alrighty I'll give it a go tomorrow, although I dont think we have a bigger mallet..Bennoz wrote:Trust me, use a bigger hammer.Daniel2019 wrote:If only that were the answer.. Im tempted to hook up the engine jack and try and lift itBennoz wrote:Use a bigger hammer
They will start leaking eventually and won't be up to par with everything else lol
The whole point of a rebuild is so the the engine is as new...
Not a mallet, a 4 pound lump hammer. It won't be the last time you use one during this process eitherDaniel2019 wrote:Haha alrighty I'll give it a go tomorrow, although I dont think we have a bigger mallet..Bennoz wrote:Trust me, use a bigger hammer.Daniel2019 wrote:If only that were the answer.. Im tempted to hook up the engine jack and try and lift itBennoz wrote:Use a bigger hammer
Thats true, fair point. Ill have another crack tomorrow.Sahin wrote:They will start leaking eventually and won't be up to par with everything else lol
And Ben, i'll see what I can find
- FTO_GPvR
I can help out if you want, when im free.
Youre more than welcome man. Anyone who wants to see how things work or take some sh*t apart is welcome to have a look. As long as I actually learn from it, unlike our last DIY day
- FTO_GPvR
yeah, while we did all the work and u just lookedDaniel2019 wrote:Youre more than welcome man. Anyone who wants to see how things work or take some sh*t apart is welcome to have a look. As long as I actually learn from it, unlike our last DIY day
Actually no, I had control of the tapFTO_GPvR wrote:yeah, while we did all the work and you just lookedDaniel2019 wrote:Youre more than welcome man. Anyone who wants to see how things work or take some sh*t apart is welcome to have a look. As long as I actually learn from it, unlike our last DIY day
- FTO_GPvR
Oh yeah the tapDaniel2019 wrote: Actually no, I had control of the tap
Have you ordered any parts yet? Like seals, gaskets etc?
Not yet. Will be a while before I start buying parts.. Im just gonna look through the engine and learn how to take it apart and put it together a little bit first. Will be a while before I have the money for it.FTO_GPvR wrote:Oh yeah the tapDaniel2019 wrote: Actually no, I had control of the tap
