Sahin's FTO
Re: Sahin's FTO
Bought a couple of parts
- rock_it
Re: Sahin's FTO
You get em for $200?
Re: Sahin's FTO
Just a couple, nothing important....
- SchumieFan
Re: Sahin's FTO
Bonnet struts!
- bjk
- Totes
Re: Sahin's FTO
Still on my ps till august so I'm saving for a wolf v550 plug in ecu now so Its an easy install and in the meantime gotta do a few little things before then like relocate battery to boot and I could probably set the oil cooler up now too. Probably even the w2a inter cooler setup aswell
Re: Sahin's FTO
Does the bonnet close with the way you bolted up the bonnet struts?
Re: Sahin's FTO
Yeah it does, I even looked at bennoz' install before tackling this lol
Oh and btw it's a f**king mission to install see by yourself! They are really hard to decompress by hand and bolt them up lol took all my strength
- bjk
- Totes
Re: Sahin's FTO
Guess the rest of us are fucked.Sahin wrote:took all my strength
Re: Sahin's FTO
Can't tell from the photo but are they bolted to the stock holes?
Re: Sahin's FTO
Stock bolt holes yeah, and even using the factory rubber still
Re: Sahin's FTO
I bolted mine to the stock bolt holes and the bonnet would not close. Struts would bottom out when the bonnet was still about 30cm open.
Had to drill a new hole in the strut bracket and bolted to the factory hole and didn't have to compress them when installing with the new hole.
Re: Sahin's FTO
You must've had them around the other way man
These bolted straight up lol
Re: Sahin's FTO
Nope, they were the right way, dstocks had to do the same thing and Bennoz went with a different route and drilled a new hole in the body.
Re: Sahin's FTO
had them like this?
Re: Sahin's FTO
Link to where you got the struts from Sahin?
Sahin's FTO
Edit here we go
Re: Sahin's FTO
Yup, exactly like that.
Re: Sahin's FTO
Mine work fine lol yay
