Is this possible? or do I need to get a complete custom parcel shelf? or can I get a 6" FTO parcel tray and swap someone for my 6x9 parcel tray? will this work??
(sorry to be brief im in a rush)
Possible to fit 6" Speakers in a 6x9 Parcel tray???
- GPXXX
- Daz_FTO
It can be done without a prob. one way to do it is to do as Mikey has said - grab a piece of MDF to fit the 6x9" area and cut your 6" circle in it. Attach the MDF to the original bolt holes. If it doesnt fit above the parcel tray you could always mount them below it. It would probably be a good idea to get some rubber from clark rubber or somewhere when making a mounting plate as they could make a little more rattle. Use it around the edges of the speaker and the mount(where u screw at least) and that should reduce any extra noise you might induce. I have mounted 7x10" speakers into my parcel tray - no probs at all!
