help with clock/battery dials
PoRKroLL
Post by PoRKroLL »
i just need help with the clock/battery dial for the fto.. can anyone tell how to remove these ones so i can replace them with new ones? anyway help is appreciated, thanks.
Raven
Post by Raven »
not sure about the dials themselves however the rubber feeling pannel that surrounds them just pops out by pulling it forward.
Whats an FTO?
Theremin
Post by Theremin »
This may help..
http://www.type-f.co.uk/new-dial-rings/ ... -guide.pdf
See the second half of the page. I've had mine out a couple of times and it's pretty straight forward except it was an absolute biatch to get the tube that connects to the back of the a/c to stay in place while you put it all back together.
ellusion
Post by ellusion »
I had the same problem. What is that tube??
ruchi
Post by ruchi »
The tube carries air to the temperature sensor in the AirCon unit, if it is not attached you will get inaccurate readings.
