Questions about 6A12TT
- overboostin007
Just wondering what is involved in a 6A12TT conversion into an fto. Is there much more work. Ie does the engine bolt up to the existing engine mounts. I know the wiring and ecu will be different. But are the drive shafts the same length etc. Just looking about and the 6A12TT engine isn't much more expensive then the standard 6A12
- jonowong
- jonowong
- overboostin007
engine
Yeah i figured i need to replace the engine anyway, and being there is not much difference in prices on the both engines that maybe if it were easy enough to do that it might be worth doing the 6A12TT.
- bigpitty1
- bigpitty1
I recon you could get a 6a13 in without much trouble, the engine should slip straight in, straight onto your gearbox, if you have a gr the 6a13 should hook straight up to the gr harness and all you have to do is change ECU's from what I have heard, I think where most of the money ends up is in the turbo as there is not much room for the twins and then custom work has to be done to make it single.
- FtoSam
Seen two 6a13tt conversions in person...
Both took over a year to complete and both took over $25k.
you need a lot of custom piping, custom cooling (thanks to the newfound turbo), new exhaust, new wiring, intercooler, ECU, tuning, CVs, intake manifold, stronger mounts, custom built clutch with stronger pressure plate, cuting of front bar and chassis to fit intercooler (you also loose air con).
And after all this, you're going to loose all your handling and traction...
Come down this way and talk to adam or jeff... both will inform you of their headaches.. Its a much bigger project than it looks...
as others have said... stick with the 6a12..
- jonowong
lol your welcome to come to sydney and fit one in for mebigpitty1 wrote:I recon you could get a 6a13 in without much trouble, the engine should slip straight in, straight onto your gearbox, if you have a gr the 6a13 should hook straight up to the gr harness and all you have to do is change ECU's from what I have heard, I think where most of the money ends up is in the turbo as there is not much room for the twins and then custom work has to be done to make it single.
- bigpitty1
I'll put the engine in but it ain't goin to be turbo'd.jonowong wrote:lol your welcome to come to sydney and fit one in for mebigpitty1 wrote:I recon you could get a 6a13 in without much trouble, the engine should slip straight in, straight onto your gearbox, if you have a gr the 6a13 should hook straight up to the gr harness and all you have to do is change ECU's from what I have heard, I think where most of the money ends up is in the turbo as there is not much room for the twins and then custom work has to be done to make it single.
