Taillight problem
speedcrushdemon
Taillight problem
Post by speedcrushdemon »
Guys my taillight doesnt seem like working alrite... when i brake, one of the four bulbs is not working. But when i turned on the lights, all four bulbs worked, but when i braked again, only 3 bulbs light up.
How could this happen can anyone help me :roll:
thanks!
Last edited by speedcrushdemon on Wed Jan 23, 2008 12:11 am, edited 1 time in total.
nicholas
Post by nicholas »
Sounds like an easy fix -
Each bulb has two elements in it; one which lights up as the tail lights (ie. on all the time) and one which lights up as the brake light (ie. only lights up when you hit the brake pedal).
Sounds like the 'brake' element is broken on that particular bulb while the 'tail light' element of the same bulb is okay. Solution - replace bulb. Cost - $1. Easy :D
BorepYano
Post by BorepYano »
why is this in the parts for sale section? o_0'
other than that... yeah replace the bulbs :)
maggsy
Post by maggsy »
My car had the same problem when i first got it.
Before changing the bulb, give the terminal (the bit the bulb clicks into) a clean with a wire brish.
If that does not work then it will be the bulb.
speedcrushdemon
thanks for the replies! i was too panic for this :lol:
kid_dynamite
Post by kid_dynamite »
moved for you to the correct section.
Dr_Jones
Post by Dr_Jones »
Now really moved to the correct section ;)
