Bennoz spends more money - NOS!
Am trying a little experiment tomorrow. Car is going down to the shop & the heads are coming off. Were hi flowing them, which includes decking (increasing the compression ratio) and porting out all ports as big as they'll go. The 2 parts of the intake manifold are also going to be ported out to match the head ports. We're also going to try & machine out the throttle body & fit a new bigger, brass butterfly in.
Will be a while before I have accurate power figures, as the car'll need to be re-tuned on the dyno when this is all done.
Will also post some piccies of all the machining work before we bolt her back together.
Optimistically I'd like to see another 20kws out of it, but realistically it probably be between 10 & 15kws.
- aza013
- NSW Coordinator
- aza013
- NSW Coordinator
- RalliartBoy
- aza013
- NSW Coordinator
- FtoSam
- SG
Ben you ever thought about putting Mivec cams in the GR motor? what cams do you have at the moment...??
all i'm thinking about at the moment is when my crank is going to let go from all this motorsport if nothing lets go before it and if it does i might just save on the gpx motor and get a GR put the Mivec cams in and have my same redline. (only with less load/resistance apparently - i cant remember why - and less weight in the heads).
- Delvance
Mivec cams in a GR motor...i don't get it...
You'd be swapping over a fair few parts and the heads to support the mivec cams i think...which would mean same weight heads. The mivec cams with breathing mods WILL need to rev past 7500 as well as they're still making power (look at my dyno sheet if you want)...
Be much better doing what Bennoz is doing right now.
Thumbs up Bennoz, can't wait till i see the dyno sheet and your driving experience with this done.
