Supercharger, what do you think on this design
- I8A4RE
- QLD Coordinator
http://www.rippmods.com/RIPP_Supercharg ... a_i4-1.htm
lookes like it would fit, ben your probably leading the way on this topic, waht do you think mate
Edit: im talking about the layout design and the type of supercharger im NOT talking about the kit
- mr-charisma
- I8A4RE
- QLD Coordinator
yeah what the hell, why are they so expensive they are half the size of a turbo
- mr-charisma
Setup for that kit seems similar to a turbo install ... so would you be looking at a similar cost to a turbo conversion? 10k or more?
Would imagine that there would be more involved with hooking it up to the belts etc? I take it thats what the tube running across the front of the engine is for?
There doesn't seem like there would be enough room for it in an FTO Engine bay... but the blower should fit well enough if the battery moves to the boot..
- I8A4RE
- QLD Coordinator
yeah i aint talkin about the kit do a google for the supercharger they are bullshit expensive and its only half the size of the turbomr-charisma wrote:Setup for that kit seems similar to a turbo install ... so would you be looking at a similar cost to a turbo conversion? 10k or more?
this setup wouldnt cost 6k to install, unless you were getting ripped. a lot less fabricating. Ben seems to recon it would fit and i do agree with him but you are right battery definitly too the boot as mine already is
- mr-charisma
yeah, i know what you mean ..
like Sam said, he got his kit for 2k or something & his install costs still landed somewhere in the 10-15k mark even before his Forging internals etc..
Couldn't imagine getting the SC kit to fit without a certain amount of fabrication.. to my way of thinking fabricating for a Supercharger might be a bit more involved than a turbo... more mechanical elements ... not just some piping to be made up..
then theres tuning, testing etc..
But anyways, not trying to pick anyone apart on it, just trying to get my head around a few things cause I wouldn't mind having one of these babies under my bonnet
- mr-charisma
- I8A4RE
- QLD Coordinator
dont be sarcastic thats my job , im not going to get into a debate about sams install, but in saying that, sam did an engine conversion followed by replacing internals etc etc. secondly look at redlines, mivec24 and talk to jonowong and they will all tell you a turbo install doesnt need to cost that much.mr-charisma wrote:yeah, i know what you mean ..
of course theres going to be some fabrication, but you dont need to run an intercooler, there are no down and up pipes which is the most expensive part of a turbo install.Couldn't imagine getting the SC kit to fit without a certain amount of fabrication.. to my way of thinking fabricating for a Supercharger might be a bit more involved than a turbo... more mechanical elements... not just some piping to be made up..
that would be the same with turbothen theres tuning, testing etc..
Oh we all doBut anyways, not trying to pick anyone apart on it, just trying to get my head around a few things cause I wouldn't mind having one of these babies under my bonnet
- I8A4RE
- QLD Coordinator
yeah ohio us
- mr-charisma
- I8A4RE
- QLD Coordinator
as ben said THIS super charger is too expensive, but if only we could find a replacement supercharger that we could setup like that, one that costs round 600-1000, now then we would be talking
The fabrication here wouldn't be too bad. It would be less than my plan with an Eaton blower. The biggest expense would be getting a drive shaft to fit (yes that long bar that runs along the front edge of the motor) or buying a standard length one & mounting the blower on ithe end of it to suit. The only thing that has to be spot on is the pulley lining up with the other pulleys. If you get that wrong you'll forever be snapping belts. From there all you need to do is fabricate piping from the blower exit to the TB. The blower intake piping can just be like a mock up CAI, plumb a pipe & air filter in where ever you like.
I dont know what computer you'd need for this setup. I dare say a piggyback would do the job as this type of Supercharging is called 'Upstream' supercharging. Upstream means the blower itself sits upstream of the TB & forces air into the TB. Kind of a softcock way to do it Well.... its a safer way to do it. It means all your intake runners, butterflys & control solenoids & sensors on the intake manifold stay the same - effectively retaining a pretty good driveability of the car, yet not producing as much potential horsepower.
My design is call 'downstream' supercharging. Ie the blower bolts straight onto the intake manifold & blows directly into the heads. My TB is then mounted on the intake side of the blower with the CAI & filter. There's more fabrication involved here & the intake is basically cut in half, all the restricitive bits in the manifold are essentially gutted out. Here I also eliminate a number of sensors & as such I need a more complex ECU to be able to finitely tune the setup. Its a loss in driveability, but would develope more power.
Agreed - but check out prices on ebay for Vortech blowers... even second hand they fetch upto 2.5K.I8AFRE wrote:as ben said THIS super charger is too expensive, but if only we could find a replacement supercharger that we could setup like that, one that costs round 600-1000, now then we would be talking
- I8A4RE
- QLD Coordinator
yeah i know, i did, i was f^&ken blown away. i dont see why they are so expensive compared to a turbo. they are like triple the price compared to a turbo
V1 S Vortech going for $1000...
http://cgi.ebay.com.au/Vortech-supercha ... dZViewItem
Yes I have supercharger alerts emailed to me from ebay
- I8A4RE
- QLD Coordinator
After closer inspection it looks like i could even mount this at the side of the engine near the back where most ppl have the turbos and run the extension to the belts behing the engine, so that it comes out above the alternator. probably only have to move the brake lines.
