need a bit of help
- darrentank2
need a bit of help
i recently installed a headunit in my FTO, because the old one was soo dodgy (it worked 1/2 the time) =.=
i connected the wires like the one before and discovered that the right front speaker doesnt work, and the 'fading' of the front speakers dont work.
i was wondering if you guys could help me out here, i should be able to directly connect the front two speakers into the head unit but im not certain of which wires i need to do it with.
ive now got a sony cdx-gt570 - the rear two speakers are connected to the rear amp so they are fine, and work with the 'fading' its just the front speakers i need a bit of help with
thanks guys
thanks guys
- xSlurpee
- nvdfto
Function Typical Wire Colors
Memory / Constant 12V(+) Yellow
Switch / Accessory Red
Ground Black
Illumination Orange/White
Antenna Remote Blue
Amp Remote Blue/White
Left Front (+) White
Left Front (-) White/Black
Right Front (+) Grey Right
Front (-) Grey/Black
Left Rear (+) Green
Left Rear (-) Green/Black
Right Rear (+) Violet
Right Rear (-) Violet/Black
i hope this helps you.
ways to fix problem.
use an battery (AA, D or 9V) connect speaker cable to each end of battery. remaining ends connect to each speaker. Use this way as an popper to see weather your speakers are still good.
if somewhere around the door molex theres an broken speaker cable best way is to re-run the cable. while your at it might as well go for a thicker cable size.
best way to go is re-run the cables to an Amp.
thats all i can think of atms.
well good luck.
REMEMBER: Tape up the wiring with ELECTRICAL tape. NEVER use duct tape.
Ground Black
Antenna Remote Blue
Left Rear (+) Green
well good luck.
Let the tunes decide
.:[Bosch Australia Automotive Department]:.
- RK1-WhiteKnight
- craigt
- harry90
- xSlurpee
- darrentank2
- craigt
reading from the start(what i should of done from the begining) front speaker wires are:
grey for right front and white for left front on the head unit. the wiring in the car wont match unless someone has run new speaker wire to the doors.
if head unit dosent fade all the way then there is more than likely a problem with the unit.
