Rear vents are a goer
- J
- rock_it
Or ... Make the vent in line with the line line that runs through the top of the 1/4 panel .. Like how the first Ferrari vent is ... Actual the set up like that in the first Ferarri would suite the FTO ....dstocks wrote:Actually, in a way I think you are right. It seems as though the theme needs to continue past the guard in a way. makes the front bar look out of place.It may just be me but I think that last one screws up the whole front end, just doesn't look right somehow
Maybe rockits idea of a slant would address that to some degree. Will have to do a little more photochopping....
Or do this (includes rockits match with front bar idea as well as the front vent)......
Mind you, my FTO is turning into an EVO
- rock_it
- RallyMad
yep looks much better but still a little of to me. I think it's cause of the 2 different lines on the side of our cars at the 3 different angles. The one Bottom of the hip, the top line where it kicks out under the window and then not to mention the line from the rear quarter forward where the bumper kicks out (the inside edge of the kick).
All of these lines run at different angles, I've been toying with the idea of a stripe down the side for a while but always get stuck with making it work with the back and front of the car. I wonder what it would look like with only the rear vent and the line through the door rubbing out somewhere along the door.
Yeah, im thinking front vent or rear, but maybe not both
- alekazam
iv always liked the ferrari f430 rear vents and oftend wonded about making a mold off a wrecked f430 or the like
<a href="http://s50.photobucket.com/albums/f303/ ... t4copy.jpg" target="_blank"><img src="http://i50.photobucket.com/albums/f303/ ... t4copy.jpg" border="0" alt="Photobucket"></a>
- alekazam
and this one i did just for fun
<a href="http://s50.photobucket.com/albums/f303/ ... 4copy2.jpg" target="_blank"><img src="http://i50.photobucket.com/albums/f303/ ... 4copy2.jpg" border="0" alt="Photobucket"></a>
- alekazam
ok third go at it. mmm i like!
<a href="http://s50.photobucket.com/albums/f303/ ... copy-1.jpg" target="_blank"><img src="http://i50.photobucket.com/albums/f303/ ... copy-1.jpg" border="0" alt="Photobucket"></a>
alekazam that looks great well done. Dstocks if you dont do that then i will
Its yours Simon. Its not that I dont like it, I think it looks great. More that I dont have the gear to do it.
- alekazam
thanks i8a4re I had a lot of fun but I decided to try some lambo rear vents instead & I think I like them more
<a href="http://s50.photobucket.com/albums/f303/ ... ide_01.jpg" target="_blank"><img src="http://i50.photobucket.com/albums/f303/ ... ide_01.jpg" border="0" alt="Photobucket"></a>
<a href="http://s50.photobucket.com/albums/f303/ ... 19copy.jpg" target="_blank"><img src="http://i50.photobucket.com/albums/f303/ ... 19copy.jpg" border="0" alt="Photobucket"></a>
I think that one needs to be rotated clockwise slightly and pushed closer to the rear wheel
- alekazam
0k how's this
<a href="http://s50.photobucket.com/albums/f303/ ... 9copy2.jpg" target="_blank"><img src="http://i50.photobucket.com/albums/f303/ ... 9copy2.jpg" border="0" alt="Photobucket"></a>
Thats much better. Notice how the top line of the vent on the green one runs parallel with the bottom of the window. Your pretty close to that on the FTO, but not quite. If you make them parallel, I think that would make it.
- alekazam
how' this
<a href="http://s50.photobucket.com/albums/f303/ ... 9copy3.jpg" target="_blank"><img src="http://i50.photobucket.com/albums/f303/ ... 9copy3.jpg" border="0" alt="Photobucket"></a>
- alekazam
ok last one
<a href="http://s50.photobucket.com/albums/f303/ ... 9copy4.jpg" target="_blank"><img src="http://i50.photobucket.com/albums/f303/ ... 9copy4.jpg" border="0" alt="Photobucket"></a>
