Stereo problems
- NimZ
Stereo problems
I have a 2 din Ultravox stereo which has decided to stop working. I've always had problems with this stereo, especially with getting cds in and out. I don't think the previous owner of the car even installed it properly as the whole stereo swings up and down. A few days ago the lights on the stereo stopped working and then yesterday slowly the whole thing stopped working. I can't even turn it on now, and my cd is still stuck in there.
I concluded that the whole stereo was fucked and planned to buy a new one. My dad thinks maybe its a fuse or lose wire but he isn't the most technical person I know. Any ideas what's wrong, and if I should just buy a new one or fix this one?
Thanks
Thanks
sounds like a problem with the power wires going to the stereo, or the unit itself.
of course the first thing to do is check the wires connecting it...trace one wire all the way back to the battery and the other to an earth point, if either of these are loose, resolder them. If the power wires seem fine and you're really dedicated you could try removing the entire unit and trying to disassemble it, *however* thats only if you're not afraid of ruining the damn thing permenantly - lol if its not already permenatly gone...mostly though, unless its a wiring problem, then the easiest (and cheapest) method is simply replacing it.
- NimZ
Thanks Hellsmurf
i'll try to get some one to check the wires, as I wouldn't have a clue what I'm doing. But I haven't got my hopes up and already started looking at new head units.
It's the whole unit that swings, I think the previous owner was just too lazy to bolt it in properly.oh yeah, also, what exactly do you mean by "the stereo swings up and down"? the whole unit, or the faceplate, or what?
We used to sell UltraVox 2 DIN head units at Strathfield when I used to work there. 95% of the units that we sold came back to us because they were faulty or eventually broke down. If you try and repair it, it will cost you more to fix it, then buying a new one. My suggestion to you Naomi, is buy a new deck and dont even bother with the UltraVox.
- NimZ
How is this for an idea, remove the entire head unit, and replace it with a 7" LCD screen, so it is flush mounted with the dash board, and you dont have a head unit in the dash. You would have to customise the dash a bit and use a bit of resin fibreglass to fill in the gaps. If you do it properly, that would make it look even more "Purdy"
Well when I got my car it had a cheapo deck in there, that I was actually happy with. It looked alright, sounded alright and I didn't plan to replace it but of course it ended up dying on me. Thought it wasn't worth fixing so I went out and bought a JVC unit and the difference in sound quality was amazing.
- NimZ
Sounds good, you offering to do it for me??How is this for an idea, remove the entire head unit, and replace it with a 7" LCD screen, so it is flush mounted with the dash board, and you dont have a head unit in the dash. You would have to customise the dash a bit and use a bit of resin fibreglass to fill in the gaps. If you do it properly, that would make it look even more "Purdy"
- FTO338
I've actually seen an aftermarket full size 7" colour screen that will fit as a double din unit, like the Merc/BMW/Lexus, it plays DVD, MP3, WMA & it can hook up to any GPS system, it also feature motorize screen so its "Purdy" too ehehhehe. I'm going 2 find more info on it, & once i do, i'll will post it upDZYRME wrote:How is this for an idea, remove the entire head unit, and replace it with a 7" LCD screen, so it is flush mounted with the dash board, and you dont have a head unit in the dash. You would have to customise the dash a bit and use a bit of resin fibreglass to fill in the gaps. If you do it properly, that would make it look even more "Purdy"
