Ive got Twins
- sublime19
- Sooty!
Yep, I can. At current rate, it would be about fifty bucks landed im guessing. The stickers come in dark grey like mine or in gold. They are about 1mm thick, so look embossed when applied.Also Dstocks I think can get them straight from Mitsubishi in Japan
It wasnt completely smooth as they didnt get a chance to finish on the day as the guy had to get to a formal or something, but I need to take it back in a couple of hundred kms, so they can do the final alignment and tidy up. I have already used a file on it to smooth it out and from the back and the holes are pretty much perfect. The one on the left doesnt have the fold under that the one on the right does, but you actually dont notice that unless you are specifically looking for it.Does it line up with the other whole and is it smooth
- aza013
- NSW Coordinator
yep I did the first one with the contact, the only time it came off is when I took it offrock_it wrote:I think Aza has used contact... and it has lasted some time ...eddiii wrote:ooo...so its called decal? lol so much work to trace over the logo...den cut it...den stick it....lol and prob when it rains it will come off lol but thanks anyway ^^
Also Dstocks I think can get them straight from Mitsubishi in Japan ... PM him first, then chace down the guy that sells them in the UK .... With the Aussie Dollar the way it is, it may be cheaper to hold off for a little while....
- eddiii
so how do i actually do it with contacts? ^^ if u have steps to it would b nice ^^aza013 wrote:yep I did the first one with the contact, the only time it came off is when I took it offrock_it wrote:I think Aza has used contact... and it has lasted some time ...eddiii wrote:ooo...so its called decal? lol so much work to trace over the logo...den cut it...den stick it....lol and prob when it rains it will come off lol but thanks anyway ^^
- aza013
- NSW Coordinator
PM on its way.eddiii wrote:so how do i actually do it with contacts? ^^ if you have steps to it would be nice ^^aza013 wrote:yep I did the first one with the contact, the only time it came off is when I took it offrock_it wrote:I think Aza has used contact... and it has lasted some time ...eddiii wrote:ooo...so its called decal? lol so much work to trace over the logo...den cut it...den stick it....lol and prob when it rains it will come off lol but thanks anyway ^^
- eddiii
Complete custom jobbie. The cat isnt moved (Although it is now a high flow cat). Only a single pipe to the rear wheels. It then splits into 2 triple flow muflers and twin pipes coming off that. All bends are mandrel bent.
