Painting Interior
- boogieee
Painting Interior
What sought of paint would you use to paint your interior? such as door panels and the centre console part im trying to DIY and make em silver.
- mr-charisma
I wouldn't .. paint is for the outside ..
Get them professionally plastic chromed or so..
Might be pricier than a can of paint from Supercheap, but its worth it.. & loads less tacky
I think this is the place..
http://www.dashboardcentre.com.au - check with DStocks though
- Tippin
- vipfto
as long as done correctly its good
fisrt light wet and dry, then clean, proper plastic primer, actual colour then gloss for protection and shine
but dont use cheap paint from supercheap etc, go for the good brands. ie duplicolor.
And if its not up to your standard then all will be have to be done again
