New I.C.E. Toy
- mr-charisma
New I.C.E. Toy
Just got this delivered a couple of days ago Now just need to get the GPS & built in Phone working & get it hooked up to the Car Entertainment system
'tis an awesome little device ... should be pretty sweet when it's set up
Processor and Chipset Intel® Processor A110, 800 MHz
Operating System Windows Vista® Business
Memory RAM: 1GB DDR2 microDIMM RAM for Vista + 64 MB for SnapVUEâ„¢
ROM: 128 MB for SnapVUEâ„¢
Hard Disk 1.8-inch 40 GB or 60 GB hard disk (manufacturer's option)
Dimensions 207 mm (L) X 129 mm (W) X 25 mm (T)
Weight 800g with battery
Display 7-inch, 800 X 480 TFT-LCD display with adjustable screen angle and touch-sensitive screen
Network HSDPA/UMTS: Tri-band 850, 1900, 2100 MHz
HSDPA: Up to 3.6Mbps for download and 384kbps for upload UMTS: Up to 384kbps for download and upload
GSM/GPRS/EDGE: Quad-band 850, 900, 1800, 1900 MHz (The device will operate on frequencies available from the cellular network)
Keyboard Slide-out QWERTY keyboard
Mouse Control Left/right mouse buttons and microPad
Wireless Connections Bluetooth® 2.0 Wi-Fi®. IEEE 802.11 b/g
I/O Ports 1 USB 2.0, VGA out, and 3.5mm stereo audio out with microphone
Card Slots 1.8/3V USIM/SIM card slot
SDIO slot with hotswap functionality
Security Fingerprint sensor
Web Camera Color CMOS VGA camera for videoconferencing
Audio Built-in microphone and dual speakers
Battery 2700 mAh rechargeable Lithium-ion polymer battery
Vista® operating time: Up to 2 hours
SnapVUEâ„¢ standby time (push e-mail enabled): Up to 53 hours
SnapVUEâ„¢ standby time (push e-mail disabled): Up to 10 days
AC Adapter Voltage range/frequency: 90 ~ 265V AC, 47/63Hz
DC output: 12Vdc, 3A max.
- koolio1234
- FTEvolution
- mr-charisma
Google maps would be cool, but this has GPS on the in built phone device, just need to hack the Phone ROM to get the GPS & Voice functionality working thought from what I can tell..FTEvolution wrote:Was just telling the missus on Sunday how awesome it would be to have Google maps in the car...
Would be a kick ass tool to tune your ECU too... yahoo!
Do you have any info or links on how I could hook it into the ECU?
I probably won't be attempting any tuning so that I don't screw things up there, but it would be awesome if I could get a readout of things like, speed, oil / engine bay temperatures, revs & have it display on the screen..
like;
http://www.qnx.com/products/qnxcar/vide ... layer.html
Been looking into getting one of these too though;
- mr-charisma
- FTEvolution
- mr-charisma
I got the HTC .. the 3rd pics was just for the car mount..Cassf88 wrote:quick question, the first two pics are of an HTC n the 3rd is of a sumsung, which phone did you get?
'tis not a phone though, 'tis a 7" Touch Screen Tablet PC running Vista (Soon to be upgraded to XP)
It also has a built in phone, so you can switch between Vista & the phone at the click of a button..
- Eltnot
Just make sure all of the components have Windows XP drivers though. A lot of laptops don't tend to have drivers written for older OS's.
I don't know why they've put Vista on that though, it doesn't have enough grunt to run it smoothly. XP will make it run faster, but have you also considered a linux OS?
Regardless, it should be a fun toy.
- mr-charisma
Quite true .. I'm going out to pick up a new SSD Hard Drive tomorrow 64Gb Micro SSD )1.8" so I'll be dual booting Ubuntu + XP .. will be interesting to see how much of the hardware is compatibleEltnot wrote:Just make sure all of the components have Windows XP drivers though. A lot of laptops don't tend to have drivers written for older OS's.
- mr-charisma
Cheers, just downloaded the Microtech Software .. The Shift doesn't have an RS232 port .. so I'll need an RS232 > USB adaptor for it (hopefully it'll work)FTEvolution wrote:What ECU you running mate? Most have off the shelf laptop software and datalogging for PC. Most others have some sort of homebrew software too.
This software should be fun to play around with.. Does the job, but the GUI could use some 'Flash' enhancements though .. looks a bit too 'Windows 3.1" for my liking..
- koolio1234
I thought platinum tipped weren't good enough for his turbo setup?Bennoz wrote:NGK Platinum PFR6J-11 (2743)mr-charisma wrote:Yep, will get them as soon as I know which onesBennoz wrote:Dont you have some spark plugs you should be buying?
- mr-charisma
- mr-charisma
Looked these up in the book while I was there & they've got the plugs for a 6a13 VR4 Galant listed as 'BP6ES-11' .. the PFR6J-11's were listed as being for the HJ Galant 6a12 ..Bennoz wrote:NGK Platinum PFR6J-11 (2743)mr-charisma wrote:Yep, will get them as soon as I know which onesBennoz wrote:Dont you have some spark plugs you should be buying?
The NGK website says that the recommended plugs are the PFR6J-11 though..
- mr-charisma
Gonna get the PFR plugs ..
I don't even think NGK know what they're doing, the website is all over the place.. but from what I can gather, the correct plugs are are the PFR6J-11's - Listed for a 'Japanese Import' 2.5L 6a13 Galant
The other plug type seem to be for Galants originally sold in Aus (apparently)
