How to register a car in QLD?
- KatieFTO
Hey thinking about moving at the end of this year, if I was to bring my car with me is there any special checks I will need to get done for them to allow me to register it etc? I've heard there is some sort of slip I have to get but I have no idea of the detials? or is there no point even trying to bring it over i've heard that aswell lol any one know?
Thanks
Thanks
Im pretty sure it is simple. A lot of NSW, people do it all the time. FTOSam has done it so if he shows his ugly mug around here he will be able to give you more info. In saying that im pretty sure all you have to do is get a safety inspection done which is pretty simple.
- KatieFTO
ohok cool cheers I've just heard it's really hard/ near imposible to get them to say there good enough without finding a million defects but i'm sure it can't be that bad or no one would get threw lolI8A4RE wrote:Im pretty sure it is simple. A lot of NSW, people do it all the time. FTOSam has done it so if he shows his ugly mug around here he will be able to give you more info. In saying that im pretty sure all you have to do is get a safety inspection done which is pretty simple.
I doubt it, QLD is pretty slack. It will be just safety things like making sure brakes work, enough tread on tires etc etc.
This is what i found, so its the same process as registering a unregistered vehicle
CLICKY
Heres some more info
CLICKY
- KatieFTO
Excallent,ThankyouI8A4RE wrote:I doubt it, QLD is pretty slack. It will be just safety things like making sure brakes work, enough tread on tires etc etc.
CLICKY
No worries at all
- FtoSam
Okay... I've done both of these...
1. As simon has said... simple.... simon... lol... Just get a qld mechanic to inspect the vehicle to make sure it is in safe working condition.. Tires are the biggest thing.... also make sure there is no bad rust, etc.. you have 2 months to do so after moving...
Also from NSW, you no longer have to get a pink slip done every year.... no more Road worthy Certs for rego.... WOOO!!!!
2. Registering a heavily modified FTO in bris is a matter of making sure everything is fine as above, however as the output is increased signifcantly, an engineer will require you to upgrade your brakes before signing off on any engine conversion mod plating... especially from another model car.. So make sure the entire thing is 100% to the letter of the law (I.e. plumb back Wastegate etc...)
If you need a list of qld approved engineers, please use the search.. i posted the list a while ago...
- KatieFTO
So as long as I havn't done any engine mods I'm ok and I'll get afull new set of tyres before the move to be on the safe side then just go get it all checked.FtoSam wrote:Okay... I've done both of these...
Great thankyou so much
- FtoSam
- KatieFTO
Yeah Its amazing up there,espically comapred to adelaide haha won't be till the end of the year if all goes to plan but I'm trying to get orgnaised so I no what I'm up for etc take all the stress out lolFtoSam wrote:No probs... I moved up here a few years back... best thing i ever did...
Post up a couple of your details in the member section once you get here, and be sure to come on a cruise sometime... (I know i am overdue)
See you in the sunshine state soon...
Thanks again!
- FtoSam
- KatieFTO
- FtoSam
- KatieFTO
- FtoSam
yeh... u need 2 things....
1 - Alarm (field sensing is awesome too)
2- garage....
i had neither in my first place i lived at... scored a heap of dints, etc....
Next place i'd fitted the car with an alarm and had a car port... never recieved a single one (Was at broadbeach)
2- garage....
- KatieFTO
already alarmed and 99.99 percent chance itll be garaged or in a gated set of houses so it sould be ok lolFtoSam wrote:yeh... you need 2 things....
2- garage....
