2.0 litre NON MIVEC V6 tappets ?
bennieboy
Post by bennieboy »
hey,
I was wondering what are the the tappets like on the NON MIVEC V6 FTOs?
I have heard that it is usually the mivec v6s which have all the problems such as rattling and requires regular adjusting.
Does the non mivec version aslo have the same problem or is it not as big deal as it is made out to be?
ta
benny
MADFTO
Post by MADFTO »
Non mivec 6a12 have self adjusting tappets, you will not have to worry about adjusting them.
Only time when they get noisy is if your oil thins out too much, which usually means an oil change =)
bennieboy
Mivec 6a12 engine tappets
Post by bennieboy »
MADFTO,
thanks for that.
Just to clarify, if the Mivec 6a12 is maintained and serviced the tappets are not an issue.
I just dont want to buy a GPX and have a noisy engine.
benny
G_A_V
Post by G_A_V »
use the right oil, and maintiain a good oil/oil filter change pattern and u should be right
MADFTO
Post by MADFTO »
*nods* just like any car, regular maintainence will keep the car in top shape =)
