Moderators: IMC , Club Staff
milspec5R
Posts: 17 jedwabna poszewka promocja
Post
by milspec5R » Sun May 10, 2009 7:14 pm
Hi guys, I have had my GPX for a while now, and the air con doesn't work, I have had it regassed. The place I used said there were no leaks, just wondering if anyone knows if it might be something else?
Posts: 4154 Joined: Mon Oct 29, 2007 5:00 pm
Post
by vipfto » Sun May 10, 2009 7:59 pm
is the compressor engaging or getting power?
milspec5R
Posts: 17 Joined: Thu May 07, 2009 5:00 pm
Post
by milspec5R » Sun May 10, 2009 8:16 pm
What is the compressor, and how will I know if it's engaging?
alekazam
Posts: 561 Joined: Sat Dec 01, 2007 6:00 pm
Post
by alekazam » Sun May 10, 2009 8:34 pm
does your interior fan work?
Post
by vipfto » Sun May 10, 2009 8:43 pm
the compressor is at front of engine on drivers side run off same belt as your powersteering (your AC pipes run into this)
check for power by checking at the AC fuse or relay under the hood with a multimeter
milspec5R
Post
by milspec5R » Sun May 10, 2009 8:52 pm
My fan works, the interior one, it just desn't blow hot or cold, frustrating, living in the Central West.
alekazam
Post
by alekazam » Mon May 11, 2009 8:00 am
thats good. whhen you switch it on does the engine idle change
Posts: 9594 Joined: Mon Aug 28, 2006 5:00 pm
Post
by I8A4RE » Mon May 11, 2009 8:09 am
milspec5R wrote: My fan works, the interior one, it just desn't blow hot or cold, frustrating, living in the Central West.
Open up you bonnet, go to passenger side, look at firewall close to the battery should be two black hoses about 20mm in diameter, that run into the firewall....... Are there???
Posts: 23668 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Mon May 11, 2009 5:47 pm
Fuse!
Posts: 9087 Joined: Mon Mar 26, 2007 5:00 pm
Post
by aza013 » Mon May 11, 2009 5:49 pm
just rip it all out you dont need it
koolio1234
Posts: 2574 Joined: Sat Oct 04, 2008 5:00 pm
Post
by koolio1234 » Sat May 16, 2009 10:42 pm
aza013 wrote: just rip it all out you dont need it
weight reduction
J
Posts: 2182 Joined: Fri Apr 18, 2008 5:00 pm
Post
by J » Sun May 17, 2009 2:02 am
koolio1234 wrote: aza013 wrote: just rip it all out you dont need it
weight reduction
open windows ftw! I never use air con
