dyno day @ Pulse Racing 18th July
- aza013
- NSW Coordinator
ok I have got the boys from work making the snags for this
I will have 5kg's of thin - 5kg's thick and 3kg's of chicken.
The BBQ has been organized so its all a go.
Also for any one that wishes to come down and have a run befor 14:00 we can start it at 11:00 and go on from there.
I will be there from 09:00 as I will be working on my car, putting the battery into the boot,adding the new air intake pipe and box and so on
- aza013
- NSW Coordinator
- koolio1234
- rock_it
Na.. Was hard not too... But since she wasn't tuned I thought it best to not risk it... Next time 4 sure...Astron_Boy wrote:Awesome day!
Was great to catch up with people.
Wish I could have stayed for the whole thing.
Wanted to see Craig run his Evo.
Did you in the end Craig?
I'll have my wagon done by then to!rock_it wrote:Na.. Was hard not too... But since she wasn't tuned I thought it best to not risk it... Next time 4 sure...Astron_Boy wrote:Awesome day!
- rock_it
Cool.. Sounds good..
Hey Aza, can you get all the photo's that were taken posted here.. Saves us having to sign up to the other forums to see them..
- aza013
- NSW Coordinator
it was a great day today thanks to all that came out for it.
We had a total of 26 cars run on the dyno and got some great power numbers
I did a test today on one of my runs, I put the air con and did the run and I have to say that it drops the power by 10KWs
I also found that the car needs to be retuned as the mivec point is dipping verry low, it lost aprox 10kws over the space of 1000rpm.
Another thing I found is that the UAS air pipe adds aprox 9kws from the pipe that I am running at this time. I did one run with the UAS pi0pe and then later I changed back to the normal pipe that I run and did the dyno again, but I will have to hang out untill the retune to be done to get a better result.
The green line is the run with the A/C on.
- aza013
- NSW Coordinator
- aza013
- NSW Coordinator
- FTO_GPvR
Aza i reckon you should post up another reply with just all the FTOs from the dyno day from that website you gave us
http://s581.photobucket.com/albums/ss25 ... yno%20Day/
I would do it if my computer wasnt broken down, it broke down on sunday . I wont be able to come online for about 1-2 weeks until i get my computer repaired. Im at blockbuster and using there computer right now lol. If i have access to a computer ill be on this site.
- aza013
- NSW Coordinator
- rock_it
- aza013
- NSW Coordinator
