camber
- J
camber
been thinking about this for a long time and need some help.
I want some camber (front and back) and have got some cash to spend to get it.
Am i right in saying pillow tops give you adjustable camber? As i've seen the tein camskill ones in the suspension thread. Would buying only pillow tops be sufficient enough to get some negetive camber?
Also what camber kits do you all have, at what degree and how long do your tyres last? Pictures would glady aid aswell.
Thanks
Thanks
- vipfto
rear has adjustable camber already
you can get the pillow tops which can give around extra 3 deg from memory or strut bolts whican give an extra 1.5 deg +/-
factory front is 1 deg already
i run
-2 ish front
-3 rear
this is prob too much for standard driving but is great for the twistys and track
it does wear tyre more obviously
also i run 1mm toe in on front and 0 on rear (its like rails)
i run
-2 ish front
-3 rear
- J
What are you using (brand, blah blah)? Any pics of the wheels?vipfto wrote:rear has adjustable camber already
i run
-2 ish front
-3 rear
- koolio1234
That would be correct.J wrote:on another note: ive heard larger and wider wheels can cause stress on wheel hubs and bearings.... is this true?
Bigger/wider wheels tend to be heavier = more rotating mass = greater centrifugal forces = more stress on hubs and bearings.
Generally though, its not too much of an issue, unless you put massively wide and large rims which will have more wear and tear in the long run.
- vipfto
minimal mateJ wrote:just what im looking for. thanks sugar im guessing your wheels are 8'' wide?
unless your going to some extrem like 4wd rims and tyres etc
- I8A4RE
- QLD Coordinator
- J
- Storm
Mine has a shed load of camber at the back due to the worn bushes it has on it
Kids skateboard up the rims and back down
But as I've done nothing to the front it means I have more understeer as the back grips a load more than the front.
Will hopefully be sorted in a few weeks when the new suspension goes on though.
