FTO GR 6A13TT Conversion
- justbecause
I ran into an issue though... the damn flywheel is 1/2 to big so thats bringing some delays..... its more for an EVO some number....
So I resort to the Fidanza Aluminum Flywheels
Ultra Light and weighs only 8 lbs
SFI approved 2 part design with replaceable clutch contact plate delivers the highest quality and longest service life of any flywheel available.
Fidanza Aluminum Flywheels are made using the highest quality, most modern materials available. The flywheel itself is made from 6061 T6 billet aluminum. It is CNC machined at a constant surface speed for durability and finish. The friction surface is very special. Fidanza uses a 1050 high carbon, alloy steel. It is incredibly durable, allowing the user to use just about any clutch disc material available. The friction plate can be machined or replaced as needed. The plates are secured with 16-20 hardened aircraft quality screws with self locking nuts which prevent any warping. Fidanza uses hardened ring gears that are swarted to the flywheel with button head screws that are counter board between the flywheel and ring gear to prevent any possible slippage. The mass at the center of the flywheel is retained for strength, but the mass at the outside is eliminated for optimum performance.
and The F1 Racing Xtreme FRX300 clutch kit
Horsepower Rating: 463 HP / Torque Capacity: 412 ft/lbs
The F1 Racing Xtreme FRX300 clutch kit utilizes an extreme clamp load pressure plate paired with a 6-puck spung-hub clutch disc. This is an excellent solution for high horsepower vehicles looking for a quick clutch engagement. The spring hub serves as a torsional damper that absorbs the shock of a harsh engagement in order to protect the transmission. The ceramic material is lightweight and has, on average, a coefficient of friction 28% higher than that of organic discs. The Xtreme pressure plate has a higher clamp load than our Performance series, resulting in even higher torque capacity.
The info is for anyone interested in the product....
- naughtika
- justbecause
No the Fidanza will bolt directly..... the first one did to but it was 11 1/2" the 6a13 req 11"naughtika wrote:if that flywheel is suited for an evo and you'll be using it for tha 6A13, I think you'll be needing to get spacers made up..
and when you do.. do you mind telling us what the dimensions are of that spacer? pretty please?
as for the spacer a guy sell them i can give you his email addy...
n.mann@mrandmrsmann.co.uk tell him you need Evo Flywheel Converter Kit.
and you got his address from antiguangenius@aol.com....
- naughtika
do you mind pm'ing me his details please?justbecause wrote:No the Fidanza will bolt directly..... the first one did to but it was 11 1/2" the 6a13 req 11"naughtika wrote:if that flywheel is suited for an evo and you'll be using it for tha 6A13, I think you'll be needing to get spacers made up..
- justbecause
his email is right there.... just email the dude.....naughtika wrote:do you mind pm'ing me his details please?justbecause wrote:No the Fidanza will bolt directly..... the first one did to but it was 11 1/2" the 6a13 req 11"naughtika wrote:if that flywheel is suited for an evo and you'll be using it for tha 6A13, I think you'll be needing to get spacers made up..
bahahahahanaughtika wrote:do you mind pm'ing me his details please?justbecause wrote:No the Fidanza will bolt directly..... the first one did to but it was 11 1/2" the 6a13 req 11"naughtika wrote:if that flywheel is suited for an evo and you'll be using it for tha 6A13, I think you'll be needing to get spacers made up..
- naughtika
yeah i deserved that.. LOLI8A4RE wrote:bahahahahanaughtika wrote:do you mind pm'ing me his details please?justbecause wrote:No the Fidanza will bolt directly..... the first one did to but it was 11 1/2" the 6a13 req 11"naughtika wrote:if that flywheel is suited for an evo and you'll be using it for tha 6A13, I think you'll be needing to get spacers made up..
.. shuddup
- justbecause
Drive Part Parts Has Arrived :)
Ok the Flywheel and clutch kit has come in so this weekend should make some serious progress... gonna try to remove the current V6 2.0L Motor, Tip-Tronic Automatic Tranny and shifter... hopefully there is no more bottle necks as far as placing the motor and 5sp manual in...... after thats cool time to wire up the electronics (harness, alternator, AC, coils, injectors, sensors etc)... oh yeah and all the other goodies like oil cooler, fuel pressure reg, wal 255 pump, fans filter blah blah blah, gonna try to fire it up on some test plugs as i wait for my Denso Iridium IK24 Plugs Order them today... man they skip my mind when i was ordering the drive train kit wednesday night..... chups... lol.... monday is holiday in the US....
oh well I will just wire up all the wire harness, gauges and sensors etc while i wait on that.....
- justbecause
Engine is Out!!!! Another bottle neck...
Well The Previous 2.0L Motor and Trip Tranny is out!!!
Dashboards is giving hells to remove... wire harness is giving hells to...
Flywheel bolts to short... due to the thickness of the New Aluminum Flywheel...
Gearbox fits BUT the starting motor hump is on the top right as oppose to the bottom left....
My Gawd!!!!! what's next???? D@mn bottle necks......
Problems!!!!!!!
Problems!!!!!!!
- naughtika
- justbecause
- justbecause
Lots of Updates.....
Site is back.... wow.... lots of updates....
On Sept 07 2009
well i go rid of the bottlenecks...
Since I am the only FTO owner in my country was hard to get access ta FTO Box so I used a lancer manual box model F5M41 which is identical to the FTO F5M42 only diff is that the F5M42 has two staring motor humps one at the top and one at the bottom... so i had to do some fabs
the aluminum spaces is needed in the 6a13 engines because the crank shaft has a liping that sticks out so the flywheel doesn't sit flush so notice the spacer has a big circle in the middle thats to go over the lipping to make the flywheel sit flush...
Notice the spacer in the flywheel as appose to the previous pics of the flywheel.....
The Spacer and bolts was done locally
On Sept 07 2009
- justbecause
On Sept 10th 2009
Well here are some pics of the engine in....
well as you see it just pinned in since we dropped it in after 10 pm...
today we should be tieing up the rest of it....
the last pic is after i cleaned the gearbox.... it was really dirty.....
PS: The Mounts are not busted, I just packed with 5200 to help save them for popping.....
On Sept 11 2009
filter wouldn't fit so i needed to get some fab done up... see pics
almost forget to block up the factory turbo return hole in the back of the engine...
i'm gonna use the front return hole and the feed from the top of the gearbox...
the second feed was on the factory oil filter relocator which removed to install my oil cooler kit.... pics will be featured soon...
On Sept 11 2009
- justbecause
- justbecause
- justbecause
Gauges!!!!
Gauges are dual each, Volt and A/F next one is Boost and EGT....
EGT and Boost not connected yet so the display is at default...
the A/F and Volt is currently active....
Off
On
Off
On
- koolio1234
- justbecause
