Grommets
Pkat
Grommets
Post by Pkat »
Just wondering where can you buy rubber Grommets for the boot lid in Melbourne. And also what are the stock standard hole sizes for the spoiler? Just wanted to check out how the boot lid looks with these grommets. Does autobarn sell these?
Dont do it, it looks crap
Grue
Post by Grue »
there are round holes, and square holes in the boot lid from memory... just whip the bonnet off and cover the holes with tape to see if you like it.
If you do, getting the holes filled and painted isn't too expensive if you shop around.
Grue
Post by Grue »
or buy a second boot lid, one for spoiler, one without, and swap at whim!
Pkat
Post by Pkat »
thanks for the advice. Does anyone acutally know hte exact sizes of these round holes and square holes? Im going to get it done properly but for the mean time i want to put the grommets in.
Grue
Post by Grue »
Cool cool.
Doubt anyone will know off the top of their heads mate... probably quicker to whip yours off yourself and measure. Just a handful of nuts. It comes off and goes back on quite easily once you've broken the seal.
Pkat
Post by Pkat »
thanks mate =]. Is there some sought of glue there which is the seal or something? I'll do it today after im done wiht work then probably head to bunnings to buy some grommets
Grue
Post by Grue »
Yeah, although I think glue is a bit too strong a word for it. Couple of smacks with the back of your hand on the spoiler will do the trick.
Pkat
Post by Pkat »
Hey just having some trouble taking off the spoiler. Lol when you said easy i thought it was really easy but seems harder then i thought, since theres no DIY how to take off the spoiler can you tell me how too i mean i took off the 3 bolts that are visible from the boot but i cant get too the other bolt in the middle cause theres this cover covering the bolt.
Grue
Post by Grue »
Well, I just whipped the visibly nuts off and that was it! When you say 'cover' you mean part of the metal is blocking you getting to the bolt, or there's a plastic cover on the nut? Got to mine fine with a socket wrench and a long socket.
Pkat
Post by Pkat »
yeah its that metal cover thats in the way which you cant remove. Ahh okay i just removed all the visible nuts and tried banging it out didnt work for me unless i didnt use enough force that is. Are you suppose to remove those nuts in the middle of the spoiler that is holding the sides of the spoiler?
Grue
Post by Grue »
Pkat wrote:Are you suppose to remove those nuts in the middle of the spoiler that is holding the sides of the spoiler?
Sorry mate, can you be any clearer than this!?
Pkat
Post by Pkat »
lol dw thanks for your help. Just had to use a bit more strength to pull it off lol i was a bit scared when i was trying to rip it off. Now for some touch up paint
Grue
Post by Grue »
ha. glad you got it in the end!
