New rims an painted blue calipers
eddiii
Post by eddiii »
Rims ar konig 19x8 +40 running on 225/35/19, And new D1 Spec forge nut coming soon :)
El_Ade
Post by El_Ade »
Great choice of rims man, they look so mint :)
Any rubbing issues? but the rims are very nice
eddiii
Post by eddiii »
thanks guys, nope, no rubbing, it couldnt turn before with 245/35/19 cause it hits the side skirt lol, but 225 is fine, even with king spring ^^
awesome so straight fit then even no spacers etc?
eddiii
Post by eddiii »
yep, straight fit, no spacer required :) i shoulda put bigger tyres at the bak, like 245 or even 265 lol
na cause then cant rotate them ;)
eddiii
Post by eddiii »
Lol wahhaa, i rarely rotate them anyway, but yeah, good thought :)
J
Post by J »
post in 'the offset thread' in the general section :D
how close are your wheels/tyres to the arms on the rear?
eddiii
Post by eddiii »
will do ^^
lol didnt check the rear cause it wasnt a problem, but the front IS REALLLL CLOSE lol, less den a finger space lol
Rambo
Post by Rambo »
did you paint your calipers yourself?
eddiii
Post by eddiii »
yep, not that hard, just degrease it an clean, then spray an clear coat after lol ^^
Sophia
Post by Sophia »
Wow, good job on the calipers :D
And great choice of rims aswell :D
zuihoujueding
Post by zuihoujueding »
hey! great rims there! nice!!!
eddiii
Post by eddiii »
thanks thanks :) wasnt use to it at the start, cause too use to the white rims lol
