New rims on, Carbon wing on
Wing is slightly longer in design over the factory I found, so annoyingly you can see the original marking of the factory spoiler, oh well.
- aza013
- NSW Coordinator
- mr-charisma
- J
did you get the wing off tenji? because mine wasnt the same as a gpvr one aswell... the two outer finblades extended longer then the oem and it was more flush to the boot ends whilst the gpvr wings sat in a couple of mm's... yours looks really good
and i thought the ssr were a bit bland before, but seeing them on your car changed my mind
- AJ
- koolio1234
- Shhtuart
Re: New rims on, Carbon wing on
Astron_Boy, are those stock side skirts?
Actually, they are no sideskirts. Some models didnt have sideskirts fitted. If you took off your sideskirts, thats what it would look like.
- Shhtuart
dstocks wrote:Actually, they are no sideskirts. Some models didnt have sideskirts fitted. If you took off your sideskirts, thats what it would look like.
I'll be honest I'm loving the facelift front with standard sides.
Anyone want some veilside skirts?
- koolio1234
Yeah, its like an optical illusion, the curvature and profile of the sides make it look like they were sideskirts...definitely had me fooled
- aza013
- NSW Coordinator
I think there is factory side skirts on there as there is end caps on at the start after the front wheels.
if there was no skirts it would not have the caps on.
- Gholdwayne
aza013 wrote:I think there is factory side skirts on there as there is end caps on at the start after the front wheels.
yehp, an fto without sideskirts looks incomplete, its just that factory fitted sideskirts are fitted really well.
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- Dan25
They are stone guards. Totally separate to the "skirts".aza013 wrote:I think there is factory side skirts on there as there is end caps on at the start after the front wheels.
I'm actually really confused as to what you guys are talking about in regards to these "skirts" though...
Agreed.dstocks wrote:Actually, they are no sideskirts
This is what confuses me. Are you saying that FTO'sdid in fact have a factory side skirt option? I've never seen it. Pics?dstocks wrote:Some models didnt have sideskirts fitted
- Gholdwayne
sure as hell looks like there are sideskirts on... on the first pic, you can see near the rear wheel where theres a line where the skirt is fitted on the rear passenger side quarter panel.. no sideskirts look flatter than that.
check again astron boy
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- aza013
- NSW Coordinator
One way to find out. Dan do you have factory skirts on?
- Dan25
Okay I think we are totally confusing the issue lol.
My car's exterior is total factory stock.
Whether you want to call the strip below the door a "sideskirt" or not is up to you. Personally I don't call it a side skirt (even though it's detachable from the main shell and it probably technically is) basically because it's factory, not aftermarket.
I've never seen a stock FTO with any other sort of "sideskirt" from the factory, nor I have I seen one without those that are present on mine and Astron_Boy's cars. Imagine how ridiculous it would look lol.
dstocks wrote:Some models didnt have sideskirts fitted. If you took off your sideskirts, thats what it would look like.
- J
some models dont come with that detatchable peice of plastic we call sideskirts, or what you call ''factory xxxx''
for example bens car has no sideskirts, it looks like it does though. the factory body under the door (without sideskirts) is the same shape BUT is shorter in hieght and flat. where as the sideskirts are longer hieght-wise and bulge out 50mm
if your feeling adventurous one day take off your sideskirt and compare it. they look preety much the same
dan its just like saying the front bumper isnt called what it is because its factory. weather its a aftermarket sideskirt or factory sideskirt... its the same thing
