hi,
i have this issue on my FTO. it a auto gearbox.
after reversing for 3sec it work fine, and suddenly the reverse gear does not work anymore when u accelerate, it just keep rev and stay still.
after trying for few hours. the reverse gear works but it just normally move slowly and no acc power at all. like in D mode the slow moving with acc.
any one can tell me what the problem?
Reverse Problem
- vipfto
Re: Reverse Problem
WTTC first
A little more detail may help like does it do it when in drive gears and have no acceleration?
So could be a few things, not engaging gear properly (maybe dodgey selector cable)
Torque convertor stuffed
needs a trans flush
try checking error codes too, do a search and you will find out how
needs a trans flush
Re: Reverse Problem
The gear are all workin fine only when engage reverse the car will not be reverse it will stay still like stuck.
Some time it will move automatically but very slow.
Step on gas will not make it faster only loud rev sound is heard
- bduffman
Re: Reverse Problem
ok so i cant be bothered to scan the page but this is what is says
inspection procedure 4
does not reverse
if the vehicle dose not reverse when the selector lever is shifted from n to r range while the engine is idling, the cause is probably abnormal pressure in the reverse clutch or low reverse brake or a malfunction of the reverse clutch, low and reverse brake or valve body.
( probable causes )
abnormal reverse clutch pressure
abnormal low or reverse brake pressure
malfunction of the low and reverse solenoid valve
malfunction of the low and reverse brake
malfunction of the valve body
MUT-11 ACTUATOR TEST
no.1 low and reverse solenoid valve
NEG. replace the low and reverse solenoid valve.
OK: sound of operation can be heard.
if ok HYDRAULIC PRESSURE CHECK
measure the reverse clutch pressure in R range
standard value(1320-1720)
NEG- valve body disassmbly cleaning and reassembly
pay particular attention to loosening of bolts and to damage and slippage of O-rings, valves and valve bodies.
if the damage cannot be repaired , replace the valve body assembly,
if ok measure the low and reverse brake pressure in R range
standard value ( 1320-1720)
if ok , reverse clutch system and low and reverse brake system check
remove the transmission assembly, valve body cover and valve body.
pistons should operate and pressure should be maintained when air is blown through the reverse clutch oil hole and the low reverse brake oil hole in the transmission case.
NEG- reverse clutch and low and reverse brake check
check for the burning of the facing, defective piston seal rings and interferance at the retainer
if ok - valve body disassmbly cleaning and reassembly
does not reverse
( probable causes )
- bduffman
Re: Reverse Problem
hope that helps , check codes first and if nothing check all that stuff ,
theses manuals have a lot of info but very confusing lol hope that was on the right track havent read all the manual yet
- payaya
Re: Reverse Problem
Good luck! Feeling it's going to cost you a few thousand to get reverse working again.
